Has somebody tried using MB C3 Mux on the laptop with no dedicated Serial Port. Instead that using just good quality USB to Serial Port converter. My laptop does not have the PCMIA card slot so option with PCMIA serial port wont work ether.
I successfully used USB-Serial converter on FTDI chip.
There are loads of USB to Serial adapters available and I have tried quite a few. Undoubtedly the one with the best driver function coverage is the FTDI. The others just do not fully implement all the serial functions or speeds. I tried for days to get various adapters to connect my linux box via infra-red to my electric meter properly. Had to scope the waveforms and go into it pretty deep to figure out it was the drivers and implementation of the lesser converters after my programming self doubt kicked in.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Works like ? charme!!!
Which brand adapter did you use?
I think must be this one -> USB RS485 Cables <-
because SD3 cable is rs232 to rs485 full duplex converter.
Just buy ? rs232 to USB adapter.
I have managed to work My DAS with Keyspan USA-19HS
DAS communicates with all Control Modules Except Engine. Kind of weird. Anybody knows what should I do to get it to work properly ?
Got it. Slowed speed to 115200. All works now
Sweet !
Make sure Your serial port is set as Com 2
i test profilic, cesar test work ok, but not connect to car, ft232 not work for me, cesar not work and car not diagnose. maybe we must use usb - 485
i test on chine c4 (small box)
I think something is missing
The hardware serial port have the ability to comute lines as far as I know no usb to serial adaptor can't do
I try PCMCIA to rs 232 work with trouble can't sincronize line and all C2 C3 and C4 fail
I think this treah is wrong
