Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    genius76's Avatar
    Dec 2012
    Lowestoft
    WHAT ERROR U GET WHEN PUTED 40168
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
  2. #17
    Ashraf6119's Avatar
    UK
    If I remember well the Steering Angle Sensor Basic Setting for MK60 is done from Steering Assist Module 44............and not from ABS Module 03..........
    Please have a look in here............
    VW Golf (1K) Steering Assist - Ross-Tech Wiki
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  3. #18
    quinnd's Avatar
    Jul 2012
    NZ
    Thanks but this car does not have electric steering, so no steering assistance module. If you look at the screen shot, VAS5054a says error_argument_1
    and ABS module not responding to login or something like that. With Diagun it just says "login failed" under guided functions with vas login is automatic or under self diagnostic you can enter code manually but it still fails. Could it be a steering wheel module coding issue? It is coded as "8" do you have info relating to coding numbers of this module? Rosstech does not have info
    This Golf is 1J (not 1K) 2002 mk4.
    Xprog-m, CarProg, MPPS,
    AK90
    SBB
    VAS5054a
    SuperVag K+CAN plus
    AD900
    CN900+4D decoder box
    4D Cloner
    Toyota smartkey maker
    Volvo Vida DiCE
    BMW GT1 DIS SSS Progman
    +loads more chinese stuff
    + the excellent help of DK forum!
  4. #19
    quinnd's Avatar
    Jul 2012
    NZ
    FIXED!!
    Asked other garage for old steering wheel module. Confirmed same part number but fitted original one anyway. Aligned yellow dot etc ....
    VAS5054a -> self diagnosis -> Brake Electronics -> Access authorisation -> codingII -> enter 40168 -> "coding successful" , back to diagnostic menu -> basic setting -> 60 -> don't hit activate, just exit again. DONE! Is now off getting alignment
    I suspect when the other garage did brakes, the customer drove home and hit a curb, then continued driving with crooked steering wheel. This brought up mechanical fault. They fitted second hand steering wheel module, then had basic setting error. I cannot explain why the procedure would not work with the second hand part but did with the original. Did not need new ECU as VAS5054a instructed. I hope this helps others
    AK90
    SBB
    VAS5054a
    SuperVag K+CAN plus
    AD900
    4D Cloner
    Volvo Vida DiCE
  5. #20
    genius76's Avatar
    Dec 2012
    Lowestoft
    hmm u not stated that swapped module
    otherwise wi will se diferens 1c0907379M 1c0907379C
    THAT CANOT BE DONE BASICS MATE
  6. #21
    quinnd's Avatar
    Jul 2012
    NZ
    Quote Originally Posted by genius76 View Post
    No it was exactly the same part number. I did not fit that, the other garage did. But didn't tell me that either until short time ago
    My part number was 1J0959654AP, both were the same
    AK90
    SBB
    VAS5054a
    SuperVag K+CAN plus
    AD900
    4D Cloner
    Volvo Vida DiCE
  7. #22
    quinnd's Avatar
    Jul 2012
    NZ
    BTW login still unsuccessful with Diagun using 40168
    AK90
    SBB
    VAS5054a
    SuperVag K+CAN plus
    AD900
    4D Cloner
    Volvo Vida DiCE
