Results 1 to 10 of 10
    Feb 2013
    Default 1.9 TDI EDC15P 130HP location of dw single value limiter
    I have an A4 130HP AWZ and have a question on driver whish map.
    Here it is:
    between 2500 and 4000 rpm the demanded driver whish under full load should be greater than 70.
    But in the logfile it is almost allways 70 fixed (see marked values):
    is there a absolute maximum driver whish constant somewhere seted to 70mg/stroke?
    You are limited by your airfolw. There is not enough air for more then 70mg of fuel.
    Quote Originally Posted by cruuz View Post
    It's data output limit.
    You don't see in logs mg/stroke values more than 70 even if real internal value is higher.
    But if you have some "know-how" you can made some changes in ECU file and remove this limit.
    Feb 2013
    Quote Originally Posted by veloseeped View Post
    Ah ok that makes sense, you have no addresse of it?
    Big thanks anyway
    Dec 2010
    Hello
    Drivers wish of AWX engine 130PS is exactly 70mg under full load. So the log is fine.
    regards,
    filecloud
    he have 77mg in DW map...
    BR
    Spain
    Only diagnostic limit. You can change this limit searching "70" in 8 bits, and correcting a offset.
    Feb 2013
    Quote Originally Posted by DaniXDX View Post
    there are many values "70" please give me the address
    Play with data of 4x112 map at $7319C
    Feb 2013
    I increased the byte at $731D1 (Normierwert Fahrerwunsch) from decimal 70 to 71 and see the result:
    Thanks a lot to everyone who helped me
