Hi all! Have Mitsubishi FUSO Canter 3C15 Euro4 (2007y.), engine 4M42T4, 3.0 liters, 145 hp, ECU Bosch EDC 7C4-6.6 voltage 12V. After reading fault codes with MUT3 I'm getting following fault codes.
Pending:
P0101 - Air mass sensor circuit.
P2279 - Air intake pipe: Leak.
P0101 - Air mass sensor circuit. (second time!)
Confirm/Stored:
P2263 - VGT1 system.
"P2263" - For this error code with the procedures in the service manual. To check and adjust. No result. Check the wiring, checked ease of the actuator and pull the turbocharger. All admission. In MUT3 in the test actuator actuators work out adequately. Nevertheless, the error code is not removed. In what could be the reason?
"P0101, P2279" - The descriptions of these error codes in the service manual do not! They are always present, even when just the ignition on, the engine is not running! Not removed. How does the ECU determines leak in the intake manifold when the engine is not working?
Checked the wiring to the air flow sensor. In order. Replaced the air flow sensor. No result. Confusing is that in the current parameters MUT3 on not the engine running, shows a slight air flow - 1.75 g/s. In what could be the reason?
PS. Service manual for this car for the European market and has not found! Help in this issue, please!
