Results 1 to 7 of 7
Thread: solo2 cfg file
    Feb 2013
    Default solo2 cfg file
    I have a solo2 and trying to install cccam 2.14.
    It worked,and i can choose it. But where do i put the cfg file, it is now in etc, but doesn't seem to work.
    TIA
    digicon's Avatar
    Quote Originally Posted by HarrySolo View Post
    TIA
    Hi HarrySolo,
    You can find all the cams for the Blackhole image if that is what you have on the solo in this thread here: http://www.digital-kaos.co.uk/forums...7/#post1662419 Thanks to Benny/9 for posting. Once you install one of the Cams then it automatically places a .cfg file in the etc folder ready to use
    Feb 2013
    thanx for the fast reply!
    I have them all installed and can choose them, can't get the cfg going. Maybe somethig else wrong.
    Do you know how to set attributes on files, i mean with what program?
    I use Black Hole 2.0.1
    Thx again
    digicon's Avatar
    Thx again
    Hi Mate,
    No need to set the attributes if you installed the ones i linked to then they are good to go, all you need to do is enter the data you have into the .cfg and away you go after activating the cam with blue button.
    V.I.P. Member dell_xps's Avatar
    also do a hard reboot, BH is a pain at times to get the cam running :-)
    HTH
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Thx again
    Cams for Black Hole 2.0.1 are specific to that image,all others wont work.
    Freck
    digicon's Avatar
    Quote Originally Posted by freck View Post
    Freck
    Thats not quite correct i am using 3 different types on my Solo2 with the very latest BH 2.0.1A image and they all work fine, the cams have been on my Hard Drive for well over 3 years, and i cannot see BH team making any new ones for there images as they as well as most other image makers dont support cams
