Results 1 to 8 of 8
    dyc's Avatar
    Default EDC16 DTC CODE OFF
    Hi , please help me remove dtc code p0546 from ecu edc16
    Thanks are welcome !
    Jul 2012
    EDC16C34 your information is wrong, it is not c34!
    Your sensor is defective, you can replace it or put off to the fap
    Babos's Avatar
    Mar 2012
    here you are.
    pass in PM
    Best regards.
    Babos.
    Bulgaria
    this DTC is EGT sensor right ?
    is this file is original ? or someone try to remuve dpf ?
    test with this file
    br
    Babos's Avatar
    Mar 2012
    Quote Originally Posted by mario38 View Post
    it is POHUJ what ecu if you know dtc map you can find this TDC and erase! only is one problem it is help ot not
    flpas have other DTC this is T sensor to short to ground i think.
    Babos's Avatar
    Mar 2012
    Quote Originally Posted by emiliogsm View Post
    test with this file
    br
    dpf is ON if who try dpfoff it is ECUSAFE
    Bulgaria
    yeah , i see that....
    single switch is on 01
    br
    dyc's Avatar
    test with this file
    br
    yes its exhaust gas temperature sensor and file is original as far I know or someone play with it before?
