Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 86
  1. #16
    Feb 2011
    Barcelona, Spain
    Quote Originally Posted by bts View Post
    Ktag pbc micro SD Card
    Surely the firmware is in micro SD card, save the content for a future backup in case of lock the interface.
  2. #17
    Top Poster + bts's Avatar
    electronic world
    Post Ktag
    Quote Originally Posted by soplillo View Post
    Do you have someone who reads this memory card?
    Car electronics technician
    I use devices
    Devices:
    Ktag(Master),Fgtech2(Master),KessV2(master),Gallet to1260,KWP2000,BDM100,Elnec(Beeprog),CDP+,Carprog, KTS550,FSA751,Launch(X431),ELM327....
  3. #18
    Default Re: KTag pictures and experiences
    Today i have remove the epoxy on sd card in my ktag
    But i cant remove it tomorow i check if there is not epoxy under the sd card support
    If its good i can read sd card in few days
    I repport when its done for post the dump
    Bye
  4. The Following User Says Thank You to jmush303 For This Useful Post:
    euroscan (10th May, 2013)
  5. #19
    Today i have remove the sd card not readable on windows because its raw drive
    So i take utility softwrae to make image of this raw drive
    RAWDISKCOPY free
    Image size 46 Mb
    I start my ktag with 1.93 software but without sd card for look the difference
    I see in info that the ktag info are same like the blocked ktag
    I re-put the sd card and re open with 1.89 software and i see my ktag is blocked
    Conclusion:
    Its not on SDCARD
    because i rewrite original image on sd card
    Same problem i have to buy a new ktag
    Maybe ftdi eeprom or upc or usb patch
    Thks
  6. #20
    i forget does someone with ktag can send the dump of his ftdi eeprom
    I test with mprog 3.5 he can read the eeprom
    This is my eeprom ftdi
  7. #21
    cp2010's Avatar
    Feb 2011
    DE
    counter lock inside in mcu
    KESS 5.028/5.030 VR - KTAG 8.000 EU PCB
    PCMFlash 1.2.0 dongle EU
    STool/MTool v1.49 EU
    ECU Flasher activation
  8. #22
    Does there is patch for rewrite good file?
    Like galetto 2 clone
    Thks for help
  9. #23
    Dec 2010
    Hi mates! , ktag clone works fine with PSA bosch 7.4.4
  10. #24
    Nov 2011
    I look that chone clone have many cables,can i ask is there any labels in that cables to know witch cable for what have to use it?
  11. #25
    autotuning's Avatar
    Default kTag Cables
    The software tells you the connections when you select the vehicle you are working on
  12. #26
    Dec 2010
    Quote Originally Posted by Roader View Post
    the cables inside in bags with labels and the software tell you what cable you need to use.
  13. #27
  14. The Following User Says Thank You to niwat_spp For This Useful Post:
    autoparty1978 (9th June, 2014)
  15. #28
    niwat_spp link doest work : Download permission denied by uploader. (0b67c2f5)
    Did you test on your ktag clone? Working 100%?
  16. #29
    Feb 2011
    Barcelona, Spain
    The link is dead, have you tried to update your ktag clon?
  17. #30
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Please new link ...
    Do not forget to THANKS !
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    FILE SERVISE .. web under construction
