Results 1 to 15 of 27
Thread: Freezing
    Member deano16's Avatar
    Jan 2013
    sheffield
    Default Freezing
    Hi all,
    Help needed!!
    Myself, my dad and my cousin have all got skybox f3, and a sea lions are all from the same person, me and my dad are having no problems with freezing or anything but my cousin has just started having problems with it freezing quiet often!!
    We only installed his dish last week and set the box up and the problem stated on wednesday night and has got worse since!!
    I just can't work out what the problem could be!!
    Any ideas anyone??
    Member Panther785's Avatar
    Aug 2012
    i would say the gift is sh!t3 and the server is overloaded which is known to happen, go back to the person you got it off.
    also we cant talk about it in this forum
    digicon's Avatar
    Process of elimination required:
    Change of firmware, Channel list, check connections, Monitor broadband speed and ping they can all have an effect on what you describe.
    Jan 2013
    sheffield
    Yeah digicon that's what i'm going to try next is the change of firmware and channel list!!
    The connections are fine but i'll recheck them and i'll ask him to monitor the internet speed and ping, thanks for your reply, i'll post again when i've changed the firmware and channel list
    P&D's Avatar
    Quote Originally Posted by deano16 View Post
    Hi mate get the box thats not working proper
    take it to your place & try it on your setup
    if everything ok on your setup then its how the box is connected at your mates place
    Quote Originally Posted by e1f123 View Post
    How can the server be sh!t3 / overloaded when the other 2 people are on the same server with no problems? wouldn't these people have the same freezing problems as well?
    DK Veteran sb18180's Avatar
    Sep 2012
    Quote Originally Posted by intel View Post
    no cause they might be using more than one s3rv3r one might be overloaded the other not.
    digicon's Avatar
    Ok Guys lets try and cool it a little with the Talk about you know what we are getting pretty close to the bone.
    Thanks Guys
    Jan 2013
    sheffield
    Yeah i've taken the box to my place and it works fine!! So it's got to be a problem at his end with the set up!!
    ok, now you have narrowed it down to his setup, is it just the $ channels that are freezing/glitching or all of them?
    If it's just $ channels then how is it connected to internet - wifi or ethernet cable?
    If it's all channels then it's not an internet related prob and most likely low signal due to dish/cable/LNB
    May 2009
    it's almost deffinitly a signal problem, either dodgy connections, or more likely misallignment of dish, 1-2 mm off perfect would cause percisely the probs you have, get it checked with a professional meter if at all possible.
    Top Poster Nutty34's Avatar
    Feb 2013
    Default Freezing
    Quote Originally Posted by jondalor View Post
    Disagree mate, no signal is LNB, cable dish etc, scramble, glitch is either a server issue or an ISP issue. If the other two boxes use the same provider then my guess would be the ISP.
    Mate a ping and tracert to the server is required here. Any high ping times or timeout on tracert will cause glitching.
    Sent from my iPad using Tapatalk
  13. #13
    Feb 2013
    Default Freezing
    Quote Originally Posted by bbb_uk View Post
    Mate who is the ISP where you are having the issues ?
  14. #14
    Quote Originally Posted by Nutty34 View Post
    I don't have issues. I'm trying to narrow down what the prob is for the OP.
  15. #15
    Feb 2013
    Default Freezing
    Sorry mate, my mistake.
