I mess with one sid305 last week. No errors on dash only dpf error. What exactly you need
Im here to help and to be helped
Need a guy with a car problem so i can test my solution prior to have a car coming to me. I managed to get all information needed for dpf off disabling and no regeneration maps actives and also no dtcs.
Structure is quite similar to PCR and i have done it 100% on them long ago, so now i need to manage to apply same ideas on this unit and need a tester.
If it doesn't appear till the end of the week, i'll have it working on my own anyway
HEX FW 48 available
Chiptuning solutions - dyno proven
I make DPFoff on this -was MeganeIII 1.5dci so if you want i can compare your solution with mine. Mine was 3bytes switch solution- car so far so good no problem 1000km
good
i have to remove a filter dpf from this nissan qashqai can someone?
hi
I have a car for a test
How can I read and write this SID305?
Send me dump in email or skype. Use for read Galetto2 EU clone or original.
CHIPTUNING dpfoff EGROFF immooff edc17,med17 EEPDOM CRC EDC17, MED17,
FGtech 2 clone dont read this ecu - strange but K-tag original don't read too. Finaly i have succes with KessV2 via OBD read write 20 min.
DPF removed succesufully
io non sono riuscito a togliere se volete vi mando ifile per confrontare qesta sid 305
English please
China clone not read. EU clone - read and write sid305))))
i can test
here have car with a friend
readed the file
is a nissan 1.5 dciQASHQAI 1.5 DCI.rar
you can help to dpf off. thanks
