Results 1 to 7 of 7
Hybrid View
    Feb 2011
    Default need to setup epg dm800hd, help
    hi im looking for te best way to setup the epg on this image
    DREAM ELITE V.133DV3 PHOENIX EDITION for SIM1-2 BL70(OCP)v2 , iv installed ts panel and cross epg but im not sure of the configuration settings i onlyt have the option for internal flash but there isnt enough space so wont install, i have a 4gb usb stick wonderd if that could be used many thanks
    Dec 2010
    Don't use internal flash. Use USB and format & initialise it using device manager in TSPanel. Then reboot. Configuration will now give you an option to select USB.
    Feb 2011
    Quote Originally Posted by The Mentalist View Post
    thanks but i dont have the device manager option? any ideas?
    Dec 2010
    TSPanel > tools > device manager
    Feb 2011
    cheers got it now, what format do i format it with? and do i make 1 partition or 2 etc , its only recording many thanks
    Dec 2010
    If i remember correctly it will only let you select one of the listed formats and I used 1 partition
    plasterer's Avatar
    Jun 2008
    Mersyside
    Yer mate that stick will do fine ,you will need to mount it first in devices ............Paul
    PAUL
