Page 1 of 32 12345611 ... LastLast
Results 1 to 15 of 535
Hybrid View
    DK Veteran Artilect's Avatar
    Aug 2009
    EU
    Default <<<<< VAG GROUP HOT START REPAIR AT ONE PLACE >>>>>
    Hallo to all. I See a lot of requests for Hot Start repair in VAG Group (Audi VW Seat Skoda) vehicles.
    It is common know that VAG group 1.9TDI PD engines have typical error. They are starting good in could state, but when the engine temperature is over 80?C the engine is starting very poor. It need some time to start.
    The problem is in Coolant temperature dependent injection starting maps. The engine is not injecting any fuel when the coolant temp is high and RPM-s are not high enough.
    Second problem is faulty camshaft sensor. The symptoms are the same just when you put modified software in the ECU there is no change, and the car is still staring poor. But this is detectable via diagnosis.
    So I think is the best to put all those problems in one place
    When you girls are posting your dumps, please give some typical amount of information too.
    Fox example:
    VW Touran 2004 1.9TDI BXE 105PS EDC16U1
    I will try to help, ones at day, and I believe that also the other DK members will love to help with solving your files.
    BR
    __________________
    If You Like My Post
    Please use the button on the LEFT side and the button on the RIGHT side.
    Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
  2. The Following 18 Users Say Thank You to Artilect For This Useful Post:
    309pd130 (11th July, 2022), angelx431 (21st August, 2013), darrynf (2nd October, 2016), dieselknecht (31st May, 2013), Fec001 (17th April, 2013), gogoli (16th January, 2014), kalelarga (7th June, 2013), marius7592 (1st April, 2017), MOBILTRONIC (12th June, 2015), Morfog (23rd February, 2019), nakrud (19th October, 2013), newyoga39 (13th May, 2013), Nio (6th April, 2013), pablo1971 (16th April, 2013), stanislav georgiev (14th July, 2015), vagva (27th April, 2016), ZIZZOU (10th September, 2013)
  3. #2
    Aug 2011
    Hi, I have a question about hot start. I use a map of VW touran 2005, BKC, 77kW, 1.9 TDI, 0 281 011 945.
    The first two pictures are orig ... 3rd and 4th are repaired with carsoftware. I understand the first map ... it look like the same as on edc15 (hot start) and know how to repair it (DK members teach me ) because I don't like carsoftware solution so much torque at low rpm - bad for DMF (DK member mislav88 teach me) ... so I repair it my way like in picture 5 ... but what is the map which is also repaired by carsoftware (picture 4) ?
    regards
    Aug 2011
    orig file of Touran
  5. The Following User Says Thank You to pipina For This Useful Post:
    mcday (6th February, 2019)
  6. #4
    Aug 2009
    EU
    Quote Originally Posted by pipina View Post
    orig file of Touran
    Hire you got your file.
    !!!! This is the last time, to give help without the information about the file !!!!
    Please read the first post.
    BR
    __________________
    If You Like My Post
  7. The Following 4 Users Say Thank You to Artilect For This Useful Post:
    BlacksunLE (7th April, 2017), dieselknecht (31st May, 2013), Mario4044 (24th November, 2015), newyoga39 (13th May, 2013)
  8. #5
    Aug 2011
    Quote Originally Posted by Artilect View Post
    BR
    I attach this file not because I need hot start repair but for reference of post #2 (I couldn't attach 6 files - 5 pics and 1 file so I attached in new post)
    regards
  9. #6
    Aug 2009
    EU
    regards
    Picture 1: Basic starting torque
    Picture 2: Starting torque after clamp 50
    mislav88 teach you good
    Its not good to raise the torque all the way from the 0 RPM, but you can always change the Axis value
    BR
    __________________
    If You Like My Post
  10. #7
    Aug 2011
    BR
    This is what I asked (I know that my english is not the perfect one )
    But why carsoftware change the "Starting torque after clamp 50" map ?.... I never change that map and all car work ok ... now will start eaven better with your knowledge - little hint
    regards
  11. #8
    Aug 2009
    EU
    Those generic software are sometimes stupid
    But anyway it is not good for the engine if you are giving so much fuel increase.
    BR
    __________________
    If You Like My Post
  12. #9
    Aug 2009
    EU
    "pipina" please download Attachment from #4 post one more time. The old one was not OK.
    Its Sunday, Im not function ok
    BR
    __________________
    If You Like My Post
  13. #10
    Nov 2009
    UK
    hello,can you please help me with cold start,i have already replaced cam sensor etc...but still got bad starting.
    VW TRANSPORTER-1.9TDI
    EDC16
    038906016AJ
    393512WinOLS (VW T5 (Original) as (All elements) - 393512).rar
    MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
  14. The Following User Says Thank You to pablo1971 For This Useful Post:
    missfixit (19th October, 2014)
  15. #11
    Aug 2009
    EU
    Hire you go.
    BR
    __________________
    If You Like My Post
  16. The Following User Says Thank You to Artilect For This Useful Post:
  17. #12
    Nov 2009
    UK
    thanks for the file,i did give it a go.and it starts better......it dont start like it should,but is alot better.and as for the smoke,there is no black smoke etc....i am going to keep a good eye on the van over the next couple of days,
    thanks again.
  18. The Following User Says Thank You to pablo1971 For This Useful Post:
    Artilect (16th April, 2013)
  19. #13
    Aug 2009
    EU
    Thanks for the feedback
    BR
    __________________
    If You Like My Post
  20. #14
    Jul 2010
    hi artilect your file for audi works like charm
  21. #15
    Jan 2010
    Romania
    Hello ! I have a problem with a 2006 Passat 1.9TDI BXE . Can someone help me please ?
    I have used MPPS v12 to read the file
    Edit : I tried to modify by myself the hot start map using winols but i don't know if it is ok. The problem is that i receive an error from MPPS : download not accepted at around 89 90 % when i try to write the modified file. If i write the original file it is ok.
