Results 1 to 5 of 5
    spiridonas's Avatar
    Default VW Passat 2.0TDI 03L907309 DPF OFF
    VW Passat 2.0TDI
    03L907309
    0281015029
    Please i need to make DPF OFF
    I read with fgtech2
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default dpf off
    here you are
    Babos's Avatar
    Mar 2012
    this is not DPFOFF but DTCOFF car miss diagnostic funcion and this solution not good!
    But free solution is free.
    try and report we all want see what hapen after writing.
    P.s we see new topic aboute help ecu brick or thank you
    spiridonas's Avatar
    Quote Originally Posted by ruffles1986 View Post
    here you are
    Hi, now the car don't appear any fault.
    unplug one injector , lambda but no says fault and fan run when switch on. Thanks for you time.
    Feb 2013
    Default code radeo golf 6 2012
    plese code radeo colf 6 2012
