Results 1 to 7 of 7
    Aug 2012
    Abidjan
    Default Error With Das/Xentry
    Hi, Can you help me, I can not connect my multiplexer with DAS / Xentry, he displays the following error
    Feb 2009
    Run Caesar test in star utilities.
    miha99's Avatar
    Sep 2009
    EU
    First check COM port setup:
    Control panel > System > Hardware > Device manager > Ports (COM & LPT). Right click on that COM port you have left enabled and and select Properties.
    Go to Port Settings tab and set these values:
    Bits per second: 115200
    Data bits: 8
    Parity: None
    Stop bits: 1
    Flow Control : None
    Then click on Advanced... button and make sure Use FIFO buffers are checked and COM Port Number is set to COM2.
    Aug 2012
    Abidjan
    Hi, I checked the config settings COM2 everything is normal, please you do not have any other ideas?
    Aug 2012
    Abidjan
    With Caesar test in star utilities I get the following message, I'll put it in ais image capture. I use the STAR C3 Mercedes
    Aug 2012
    Abidjan
    Please help me
    DK Veteran cocoh's Avatar
    Jun 2009
    Quote Originally Posted by Toutancamon View Post
    Hi..
    Bad configuration.. first check cal.ini
