Hi can some please help me out with password/unlock for allison v8.0.0 key: 173888717388
and the reprogramming key is :1001585664 and i would also need the password for this if possible. thak you in advance
THANK YOU AGAIN, THAT AWESOME, THERE IS TWO OTHER KEYS FOR ENGINEERING USE ONLY AUTHORIZATION KEY IS 1001585664 AND THE OTHER IS ADMIN PARAMETERS KEY 1000261856, I FIGURED IF C IF YOU CAN GET THOSE PASSWORDS
I've got an Activation Key for 8.4 of 468505946850 that I could use a Password for and a Reprogram key of 1002602626 that I need a password and Serial #. I had 8 and then upgraqded to 10 and activation is a mess so I went back to 8.
Thanks in advance.
This is a double post for I didn't realize I posted in the Allison 9 thread.
Kitty Hawk. Couldn't get my 10 working even with new activation so i went back to 8.
Didn't work. Invalid password
I have a problem connecting my laptop using Allison Doc ver 8 and my nexiq usb-link
It connects to data viewer fine but when I try to connect to the transmission it connects and brings up all the information then after 2 or 3 seconds disconnects, I've tried 2 different laptops with ver 8 installed same thing. While I was there I connected to the Cat engine with my nexiq usb-link and it worked,
Any suggestions?
Dive Naked,
Everything looks bigger underwater!
Unclick auto connect and click connect-advanced setup. Then choose the exact interface and connection J1939, J1708 or J1850. With the DPA5 I have to use this method or it will kick me every time.
Thanks alsop for the reply,
I did try that and had the same results
I'm not sure what's going on with this.
I'm going to try another truck this weekend to make sure it's not the trans ecm
Dive Naked,
Thanks guys but I still get invalid password. I went into redgit and changed date so I have 365 days to activate.Only thing is I can't reprogram. Had 8.4 running fine and then screwed up and went to 10. That's was a nightmare so I thought I'd go back to 8.
Hi there could I get the activation password for key: 210319210319
Fool2cool (13th April, 2013)
How can I get Verison 8.0?
