2008 Ford Focus 1.6Tdci PSA engine. Car occasionally gives momentary hiccup. Allways only for 1/4 or 1/2 second stutter. Can happen hot or cold cruising or accelerating. Seems totally random. Happened 2 or 3 times on first test drive. Drove car for 10 miles only happened once. Originally 4 faults stored but none of these have returned.
Original faults
U0073 Can Communication Bus Fault
P193B Throttle/Pedal fault
P1936 Clutch switch/sensor signal
U0416 Invalid data received from VDM
Don't know if these have any relation to the problem, because no faults now. Where do you start.
Just thought I'd put it up in case anyone has come across similar.
