"Huh, just eating cheese and onion slice," My god DK has turned into facebook
Meat-Head (30th January, 2018)
iv repaired the joints on the dash and tried a donor dash still no revs when pedal pressed
Whats live data showing?
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
live data on the pedal is good with igniton on but when engine is running the pedal is non responsive in live data
i have coded in a donor dash and its made no difference. the previous page with the auto data diagram i have no continuity on two of the wires from pedal to dash but unsure if auto data is correct
disconnect your egr valve and if revs up put new one
IN my case , I have good signal to ecu from pedal, but no good data pedal to dashboard
Al dash joint"s solder , in Dash I have dtc 1750 in ECU P193B and P0483 because I have adapted one Used ECU
Brs
My work is my life ART TECH GARAGE
There is no strange thing going on that ford. No such voodoo exist. If isn't a cluster problem, then, your fix will be THIS: https://www.digital-kaos.co.uk/forum...=1#post4163542
And stop the forum pollution with salamy and onion eaten on newspaper crap. Get real and get better.
