Results 1 to 9 of 9
Thread: Clio 2010
    Planet earth
    Default Clio 2010
    Hi all, i have corrupted the dash eeprom data, 24c04, used data from other dash and works ok, but now the radio works 10s and go off, any solution?
    Quote Originally Posted by leowii View Post
    hello
    you must to change the vin in the tacho !!!
    put your dump and your vin!!
    regard
    Planet earth
    Quote Originally Posted by newgeniehex View Post
    hello
    regard
    Already add, same thing after 10s go off.
    hello
    before you change the dump it work or no ?
    look fuse
    regard
    Planet earth
    hello
    look fuse
    regard
    Yes, before all works!
    fuses ok
    fuses ok
    hello
    have you put a good dump sw it is same?
    how many needle ?
    put your modele tacho maybe i have a good dump
    regard
    securipro38's Avatar
    EU
    Your dump must have same version that original and try to change CRC1 and CRC2 ( 2 bytes after vin number ) .
    If you want to know it you can read you radio dump anc copy the vin + CRC1 CRC2 or you can post your vin number or send it in PM in will give it to you
    Planet earth
    Quote Originally Posted by securipro38 View Post
    works!
    EU
    works!
    Hi the problem was the 2 bytes checksum after vin number ,correct?
