Yes its possible
Yes its possible
Im here to help and to be helped
I will recive today ECU. I supposed it is MPC 5XX ecu.
Is it correct?
yes you can read write with many different tool, galletto, mpps, bdm ecc ecc
Ecu tuning, DPF, EGR and FLAP remove
Not use programm for dpf off. All not work - include swiftec. Need only manualy. Combination metod. Swith metod not worked))) (use 90% tuner)
CHIPTUNING dpfoff EGROFF immooff edc17,med17 EEPDOM CRC EDC17, MED17,
Does somebody know where are the maps and switches for dpf?
It will help if somebody has tested file + original for comparation.
I just recived ECU. But I got problem to connect Galleto2 to ecu over BDM port.
It is MPC564MZP56B MCU - but BDM port is not clear to me.
Pictures in attachement.
Thanks!
Last edited by tihiuvek; 15th March, 2013 at 03:37 PM. Reason: Insertation of the pictures
you have instruction for BDM in c:\FGtech\documents\BDM_MPC
for dpf off file first read your ori file, then upload on forum and wait for free file or pay professional tuner for tested solution
Thanks my friend it was clasic Bosch BDM port.
So I will attach flash dump, hope that someone can help.
BIG THANKS!
ECU has been instaled in car and works for now (It is under test and I will have info back on next Friday)!
BIG THANKS!
As I got plenty of demand for these file and I am not the owner + I do not have confirmation yet, please contact member KGB20 for pass!
I repeat I do not have authorization to share pass.
So, today I received car back and it has smoke on eghsaust pipe!
DTC P14A2 i P14A6 (DPF pressure sensor).
Does somebody know same solution for these problem.
Sensor fault.
Proper solution not need any sensors connected
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
I been reading for same "HYBRID" solution! Strange that these error was not present before.
Is there any software modification possible as Ecutuner said?
