So the used PCF7936 belongs to the car.
How can he to program the blank Motorola mcu?
This is not clear for me.
Does car write the dump into the mcu under remote resync process?
I made a Peugeot 307 remote with mihotd's help 1 month ago.
First I had to read the data from the Motorola mcu.
Then mihotd collegue calculated a dump for PCF7936. His dump included the remote ID.
So the remote ID there is in the mcu.
It is 100%.
Ottife your friend lied you or you understood something wrong.
I don't know whether that one motorola chipset is a MCU inside or it is just a non-intelligence logic circuit to do rolling code algorithm without a MCU.
Did you try this way, just write the 3rd line into transponder then pair and sync the knob with car?i.e. the car only need to know the remote type then know how to decode it, the car don't need to verify something of remoteID.
------45+----
Hi to all
wich software you use to open psa reader , i have a usb to uart
jset (20th June, 2019)
Hello
which tipe to Rf receiver you use
no one can give this algo !!!
mihodt PIC connected to this, and usb-serial FTDI
https://www.aurelwireless.com/wp-con...201139G_sf.pdf
Like this...
asto (14th October, 2021), Faraday (1st March, 2020), jset (21st June, 2019), mexanico1971 (11th January, 2023)
