Originally Posted by
Zmann
AM OOK 433.92 MHz
Is AM OOK known by another name?
Every capture here seems to have XX AA ... whereas my SDR capture using rtl_433 has a fixed first byte and then variable second byte
Here's the analysis:
$ rtl_433 -r g001_433.925M_250k.cs16 -A -a
rtl_433 version 19.08-24-g14c5b9a branch master at 201910071222 inputs file rtl_tcp RTL-SDR SoapySDR
Detected OOK package @0.096508s
Analyzing pulses...
Total count: 212, width: 120.98 ms (30246 S)
Pulse width distribution:
[ 0] count: 164, width: 232 us [228;252] ( 58 S)
[ 1] count: 46, width: 460 us [460;468] ( 115 S)
[ 2] count: 2, width: 1184 us [1184;1188] ( 296 S)
Gap width distribution:
[ 0] count: 162, width: 220 us [212;228] ( 55 S)
[ 1] count: 48, width: 452 us [448;460] ( 113 S)
[ 2] count: 1, width: 940 us [940;940] ( 235 S)
Pulse period distribution:
[ 0] count: 150, width: 456 us [456;464] ( 114 S)
[ 1] count: 26, width: 684 us [680;692] ( 171 S)
[ 2] count: 34, width: 916 us [912;920] ( 229 S)
[ 3] count: 1, width: 2128 us [2128;2128] ( 532 S)
Level estimates [high, low]: 1872, 17
RSSI: -18.8 dB SNR: 40.3 dB Noise: -59.2 dB
Frequency offsets [F1, F2]: 1040, 0 (+4.0 kHz, +0.0 kHz)
Guessing modulation: Pulse Width Modulation with sync/delimiter
Attempting demodulation... short_width: 232, long_width: 460, reset_limit: 944, sync_width: 1184
Use a flex decoder with -X 'n=name,m=OOK_PWM,s=232,l=460,r=944,g=0,t=0,y=1184'
pulse_demod_pwm(): Analyzer Device
bitbuffer:: Number of rows: 3
[00] {146} ff ff ff ff ff ff ff ff ff ff ff 7b 86 69 b4 7e ef 07 c0
[01] {64} fd ee 19 a6 d1 fb bc 1f
[02] { 0} :
rtl_433 supports the following formats:
<modulation> is one of: OOK_MC_ZEROBIT : Manchester Code with fixed leading zero bit
OOK_PCM : Pulse Code Modulation (RZ or NRZ)
OOK_PPM : Pulse Position Modulation
OOK_PWM : Pulse Width Modulation
OOK_DMC : Differential Manchester Code
OOK_PIWM_RAW : Raw Pulse Interval and Width Modulation
OOK_PIWM_DC : Differential Pulse Interval and Width Modulation
OOK_MC_OSV1 : Manchester Code for OSv1 devices
FSK_PCM : FSK Pulse Code Modulation
FSK_PWM : FSK Pulse Width Modulation
FSK_MC_ZEROBIT : Manchester Code with fixed leading zero bit
I've ordered the 12F629 so I can try it from that side too. I'm sure I must be able to do it with a logic analyzer too, but haven't tried yet.
