Page 20 of 32 FirstFirst ... 10151617181920212223242530 ... LastLast
Results 286 to 300 of 477
  1. #286
    Sep 2016
    All your 3 remotes dont belong to aygo/c1/107.
  2. #287
    Oct 2019
    Quote Originally Posted by qeso705 View Post
    Yeah. Figured as much. Do you know what ID byte they should be?
  3. #288
    Sep 2016
    There have diffrent format as far i know.
  4. #289
    Oct 2019
    Ok. 4th attempt at buying the right keefob in progress. Maybe know tomorrow, but otherwise away for a week.
  5. #290
    Oct 2019
    Got another fob which works with the 107 door opening/closing programming sequence. This fob transmits differently to the other ones discussed on this thread though is a 73373067D. It transmits for 165ms rather than 120ms like all the others. Will look into it further as still interested in figuring it all out.
  6. #291
    Member vanders's Avatar
    Nov 2018
    Costa Blanca - Spain
    Turn the other way.. bsi from other (donor ) car with the original remote, and reprogram the ecu ( original one ) might work.. ? ( with the locks original belong to the car )
  7. #292
    jodge's Avatar
    Mar 2017
    wooooow
    Okay it's something like you trying to push the broken car with a towing rope.
    why don't you find a locksmith???
  8. #293
    Nov 2018
    Why dont we buy a new car? there,s also a challenge to do things by yourself..
  9. #294
    Oct 2019
    Spain
    Thumbs up
    Fantastic mihotd program modified for the pic12f675 (hex + asm)
    Thanks to mihotd.
  10. The Following 5 Users Say Thank You to clinxer For This Useful Post:
    Col19 (23rd June, 2021), mexanico1971 (11th January, 2023), tawaf111 (9th January, 2023), vavrich (7th December, 2023), YASS59 (24th January, 2021)
  11. #295
    Jun 2014
    What about these type of new keyless entry keys? Any luck ?
    As far as i know these are using PCF7945
  12. #296
    Sep 2016
    What it have cross points with old PSA remotes?
  13. #297
    Dec 2019
    Quote Originally Posted by ottife View Post
    I sure they replaced the motorola chipset 75076228. Because I also purchased one 75078226 for backup but I didn't use it, for the key of my Picasso never broken, and I found my chipset is different , my one is 75078020 , at last I re-sold the chipset to other guy and he told me the fix is successful.
    This thread suggests that the 75076228 could be an MC33493 (PLL Tuned UHF Transmitter for Data Transfer Applications).
    https://www.eevblog.com/forum/repair...fying-rf-chip/
  14. #298
    Oct 2019
    Quote Originally Posted by kocricrude View Post
    The 75078020 is a MC68HC908RF2 which appears to contain the MC3349x as the transmitter module. I've ordered a few of those RF2s to play about with, but won't get them until Jan.
    The MCU part of the RF2 is this one I think MC68HC908RK2. I got a 73372647G fob off ebay which seems to have these two as discrete components.
  15. #299
    It's HC908 and there is "SS" implemented like conventional HC908's. How does your plan to manage to get the correct SS ? And this is a three volt MCU core.
  16. #300
    Oct 2019
    Quote Originally Posted by Zmann View Post
    I don't have a plan, this is just out of personal curiosity. Maybe clock or voltage glitching, maybe there's a logical vulnerability that leaks memory via a side channel. The other alternative I thought of was reverse engineering the keydiy implementation, but I'm guessing that is well protected, perhaps more so than the 908.
