Results 1 to 7 of 7
    Sep 2009
    Default Key Volvo V40 30865186
    Hello.
    I'm trying to generate key volvo V40 2000 1,9d immo3 id44 transponder (PCF7935).
    Unfortunately effi generates bad the transponder, the starter does not turn, immo flashes.
    Can someone correct input to generate a transponder pcf7935?
    immo box 30865186 orginal key lost
    Thank you in advance and best regards.
    Mar 2018
    Quote Originally Posted by janusz21 View Post
    Hello.
    Hello, your file is good, add original or aftermarket 7935. If not, check the solders. During warming up, some SMD parts may have broken solders and swelled.
  3. The Following User Says Thank You to musti418 For This Useful Post:
    janusz21 (6th April, 2024)
    richard27's Avatar
    Aug 2011
    merhaba 7935 veri ++++++++++++++
    ​information sharing
  5. The Following User Says Thank You to richard27 For This Useful Post:
    janusz21 (7th April, 2024)
  6. #4
    Sep 2009
    Thanks for help problem transponder or programer ,immo emulator and car start
  7. #5
    Mar 2018
    Hello, is there an emulator in these vehicles? When there is a problem with the immo box in problematic vehicles, it always works when I find a similar file that works and install it together.
  8. #6
    Sep 2009
  9. #7
    May 2020
    Effi does not work good with this volvo immobilizer. I had a problem when I did AKL, only the first TP that I made worked ok, every other one could not start. Maybe tango or tmpro work better.
