Page 22 of 32 FirstFirst ... 121718192021222324252627 ... LastLast
Results 316 to 330 of 477
  1. #316
    Sep 2013
    garage
    and what keydiy is working ...keydiy mini ...?
  2. The Following User Says Thank You to Mr BLACK For This Useful Post:
    mnem (30th May, 2020)
  3. #317
    Keyblade's Avatar
    Aug 2019
    Croatia
    Any Keydiy, kd900,kd-x2,mini...
    Sent from my Commodore 64
  4. The Following User Says Thank You to Keyblade For This Useful Post:
    Mr BLACK (20th May, 2020)
  5. #318
    Feb 2014
    Yes, they all work. It was solved long ago.
  6. The Following User Says Thank You to autoTkey For This Useful Post:
  7. #319
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by autoTkey View Post
    Sorry not.
    Today tested with an old kline 307 with keydiy. Nothing working as usual. Only renewed factory remote.
    Sir, are you classified as human? Negative, I am a meat popsicle
  8. #320
    Feb 2014
    Hadn't such problem. If you generate the right remote it works. Old non-folding remotes were problematic but I think they fixed them 1-2 years ago - haven't test them for a while actually. Folding remotes were not a problem. At least on the cars I had...
    Other people also shared same experience, it seems:
    Downside is sometimes you have to go through the full list of possible or impossible keys to find the right one.
  9. #321
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Not true, some ID's not fixed till now
  10. #322
    Feb 2014
    Ok, maybe I didn't test everything. Which are not working? Need to send signal to KD then...
  11. #323
    jodge's Avatar
    Mar 2017
    Renew or factory new
    PAGE 6: 0A5AFFFF
    Peugeot 307. PN:6554RC
    this is working for Peugeot 307
    I didn't found type B or type A or any differences like in kd. If it's 307 then it will working. Period
  12. The Following 2 Users Say Thank You to jodge For This Useful Post:
    baddaren (28th January, 2023), mnem (30th May, 2020)
  13. #324
    Feb 2014
    Don't know where can one find factory new remotes of this kind.
    As I said KD worked on all cars 307 I tried - k-line or CAN. Sometimes you need to be persistent and try all possibilities but it works.
  14. #325
    Jul 2014
    Sofia
    Yes, it is working only for 307. Keydiy do not support any of the other non-flip type remotes. Do not waste your time with it on VAN/CAN type cars.
  15. The Following User Says Thank You to RFRemotes For This Useful Post:
  16. #326
    Feb 2014
    Not true... I've got to make some videos next time. I'm puzzled how come so many of you guys didn't succeed with KD.
  17. The Following User Says Thank You to autoTkey For This Useful Post:
    Keyblade (25th May, 2020)
  18. #327
    Keyblade's Avatar
    Aug 2019
    Croatia
    Wait for video! Thanks
  19. The Following User Says Thank You to Keyblade For This Useful Post:
    jodge (26th May, 2020)
  20. #328
    Jul 2018
    Default 73372647G 307 2002
    I also had a problem with Peugeot 307 2002, the original remote malfunction, I tried to program a new type of remote, VVDI But I failed to program the remote and the car is working. Is there a solution to the problem? I am tired of the problem
  21. #329
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by mnem View Post
    yeah renew few used one and you'll be fine
  22. #330
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    I have solution.
    For use xhorse remote on Peugeot 206 and also 307.
    Tested many time.
    Check video.
    https://youtu.be/4ML266fzPto
    With Tapatalk
  23. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    bresto100 (24th April, 2022)
