jameso1985 (15th March, 2019)
I have a trade customer with 3 2009-2010 Octavias. All three have the same fault. The left indicator on the dash, the battery light and the bonnet open warning light are all lit dimly as soon as the dash is powered up. The lights work fine otherwise but when they're off they aren't fully off.
Has anyone come across anything like this with this clusters?
Thanks,
Ronan.
Are these three lights close together on the dash ?
It could be just light leaking from another part of the dash which will look like other lights faintly lit.
If the white plastic mould that sits on the PCB is not tight the light can leak out.
open one to see ...
light switch round bezzel clip out ..
right and left trim trim piece clip out ..
you will see 2 torx..
leather steering shroud pull out 2x torx for speedo..
2x hidden clips top of speedo either side use thin steel ruler ..
dash pod pops out..
good luck..
I have it out and open. The leds definitely are lit dimly. I haven't examined it thoroughly yet, just thought someone may have seen it before.
Ronan
I have skoda Yeti on same problem can enybody help? Right indicator led, stering led, low beam led coming togheter. Is no any leking, dash first time open, I try swap some parts from second dash
I replied to your PM.
Ronan.
Sent from my HTC One X using Tapatalk
these are known to have faulty led drivers,
It could also be that 1 led is broken and this makes other leds in same circuit light up a little bit.
amigokola (12th February, 2017), jameso1985 (15th March, 2019)
did anyone find a solution for this fault . I have skoda with same problem .
regards
sparkle
please add rep & thanks if my post was helpful
I have the same problem with skoda octavia 2010 any one just explain what happend please
Thanks Greg
hello
has anyone fixed this fault yet ?
seems to be leak back to some leds
replacing leds does not fix .
Replacing led *does* fix it, but you have to find the responsible led.
Also maybe you have a different problem perhaps ..
Seems to be a very common problem,
Sent from my SM-G930F using Tapatalk
I have replaced so many LEDs and still no fix .
can anyone who have fixed these PM me if you do not want to share .
regards
sparkle
