Results 1 to 4 of 4
    Feb 2012
    Default MGCamD 1.38 - Black Screen Stutter
    Hi Guys, Got everything working fine.
    Except when I'm viewing channels - It flickers. Goes off and then back on, when it goes off, it's just a black screen for like a second but then it's working fine.
    Occasionally, when I see the ECM info, it's showing connected fine - but it's a constant black screen, with all relevant information coming through. ECM Times are fine when this also occurs...
    Any ideas?
    Here's my config file
    # EMM messages
    # 00 don't show any EMMs (default)
    # 01 show only valid EMMs
    # 02 show valid and bad EMMs with complete data display
    M: { 01 }
    # ECM messages
    # 00 don't show anything about ecm
    # 01 normal mode, show pids processed, decoded ecm and cw
    # 02 verbose mode, show valid and bad ECMs with data
    C: { 01 }
    # AU
    # 00 disable, no emm pids processed
    # 01 enable, emm pids always processed for soft-au and shared cards
    # 02 auto, emm started only if channel cant be decoded
    # 03 process emm pids for network cards update only
    A: { 01 }
    # key update (sum 01 or 02 with 04)
    # 01 update only new keys, default setting
    # 02 update all keys (used for valid PMK checking)
    # 04 enable TPS au
    # + tps SID, which pmt pid contains au pid
    U: { 01 } 0x12c0
    # config files folder (softcam, autoroll, ignore/priority)
    # 00 files in /var/keys
    # 01 files in /tmp
    T: { 00 }
    # network mode, use summ for several clients
    # 00 no network (default)
    # 01 newcamd netclient
    # 02 radegast netclient
    # 04 camd3 netclient
    # 08 gbox netclient
    # 32 cccamd netclient, card list saved as /tmp/cccamd.info
    # (ECM only, supported server version up to 2.1.1, later not work)
    G: { 01 }
    # network retry, use summ for several options
    # 00 disable
    # 01 retry every new ecm
    # 02 try to connect to offline shares every Q: seconds
    # 04 try to detect and fast reconnect to lost (and not used atm) server
    # + XX messages number and YY seconds to reconnect
    # mg will reconnect to server, if no answer to last XX ecm/keepalive or
    # if no answer for last ecm or keepalive sent for YY seconds
    # set to 0 to disable
    N: { 07 } 5 30
    # network ecm timeout in seconds
    K: { 05 }
    # newcamd dead routes connect retry, sec
    Q: { 600 }
    # network shares priority
    # 00 gbox, newcamd, cccamd, radegast, camd3 (default)
    # 01 camd3, radegast, cccamd, gbox, newcamd
    # 02 cccamd, newcamd, camd3, gbox, radegast
    P: { 00 }
    # on screen display type
    # 00 No OSD (default)
    # 01 neutrino
    # 02 enigma
    # 03 relook
    # + user password for http auth
    O: { 00 } username password
    # on screen display Options, summ of:
    # 01 show emu ecm
    # 02 show network shares messages
    # 04 show decoding failed / fta
    # 08 show emm keys update
    # + web port to use for osd
    S: { 03 } 80
    # Log option, summ of:
    # 00 off
    # 01 network udp log
    # 02 log to console
    # 04 file, appended ! delete it by yourself, before it eat all your hdd
    # + IP udp-port log-file-name
    L: { 03 } 172.16.1.1 28007 /tmp/mgcamd.log
    # keep ecm cache, seconds
    # every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
    # for openbox/elanvision users with remote shares make sense to set it higher than default value,
    # to not hammer cards while timeshifting or playing crypted recordings.
    E: { 15 }
    # cache option, summ of:
    # 00 Off (default)
    # 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
    # 02 Ecm data cache, remember CW for (E time
    # 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
    H: { 07 }
    # reread files, summ of:
    # 00 No (default)
    # 01 reread config file on channel change (including priority and ignore, but not replace/cache)
    # 02 reread SoftCam.Key on channel change
    # 04 reread SoftCam.Key if file changed
    R: { 00 }
    # debug, summ of
    # 00 off (default)
    # 01 debug ecm
    # 02 debug emm
    # 04 debug network ecm
    # 08 debug network emm
    # 16 debug network login
    # 32 show mem/cpu stats every 1 min
    # 64 add timestamp to log messages
    D: { 00 }
    # box type
    # 00 autodetect, change only if you think wrong type detected.
    # 01 dbox2
    # 02 dreambox
    # 03 triple-dragon
    # 04 relook
    # 05 openbox
    # 06 dreambox/mips
    # 08 stapi/kathrein
    # 09 stapi/ipbox
    # 11 stapi/openbox
    B: { 00 }
    # map all 180x nagra caids to 1801
    # default is 01
    F: { 01 }
    Any help would be appreciated.
    Cheers
    Feb 2012
    Also, that was the Dream Elite image with CamD.
    I've just installed an OpenPli image, and it's doing the same with Cccam 2.3.0
    To add finally, it's not the feed. Just took it off (and that leaves the picture on). When this goes off, picture and sounds goes off.
    DK Veteran andy211081's Avatar
    May 2009
    Doncaster
    change B to 6
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
    Apr 2013
    mgcamd 1.38 not working on bh2.0
