Results 1 to 15 of 15
    genius76's Avatar
    Dec 2012
    Lowestoft
    Default CARPROG AND IVECO DAILY 2004 2.3 HDI
    How to read and where,if of course possible for milage cheinge.
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    has tachograph?
    genius76's Avatar
    Dec 2012
    Lowestoft
    Uf got question
    mean coming asked and go, tell that coming monday
    rely no idea
    dash 93s56 and tachograph 24c04
    and if newer dash without tacho has 95040
    genius76's Avatar
    Dec 2012
    Lowestoft
    Quote Originally Posted by d.zio View Post
    93s56 can i read by 93c56?
    not sure?do you have upa usb?this read it surely....and carprog i think
    genius76's Avatar
    Dec 2012
    Lowestoft
    no only carprog
    i not big fan on these thing
    just play for much tastier bread
    Meat-Head's Avatar
    Quote Originally Posted by genius76 View Post
    OFF TOPIC:-
    I tried to read SHASHO engine ecu eeprom was a B25??
    was infact a 93S56 but i tried to read as 93C46 and just got
    dump full of "9F"
    So not going to be defeated i installed the new immo off dump in an 93C66 refitted the ecu and sent it on it's way.
    The eeprom, i taped it to a can of Poundland grey paint and sent it to PremierD for an xmas presant (this CAN be verifiyed)
    The engine ECU also stores the miles. (DK RUMOR)
    genius76's Avatar
    Dec 2012
    Lowestoft
    OFF TOPIC:-
    dump full of "9F"
    That is great answer m8 thanks will tomorrow send him to pauland for green glasses
    I do not have very much experience for these things so i don't play if i not sure that i win
    You will have problems with iveco if you dont read as an s chip read as a 93s56 not a c56
    Meat-Head's Avatar
    If you do get ptoblems just stick eeprom yo can gret paint and post to
    Cafe incorrection
    Scotland
    DK Veteran chrismoore02's Avatar
    Jul 2011
    England
    Default Re: CARPROG AND IVECO DAILY 2004 2.3 HDI
    Don't forget the complementary jump leads too
  13. #13
    davecooper47's Avatar
    Dec 2010
    UPA.
    Read protect register and make a note.
    Clear protect register.
    Change data.
    Write protect register.
  14. #14
    Meat-Head's Avatar
    Quote Originally Posted by davecooper47 View Post
    UPA.
    Change data.
    Cool can you explain more please?
    As milage is a contiunus opperation. Why protect it?
    Or does it stop jump dtsrting corrupting?
  15. #15
    Dec 2010
    In my experience these eeproms are best dealt with off the board. I can't answer why these eeproms work like this (I presume it is because they have a security byte) but this is my experience. These eeproms are in some of the 5 series BMW's & this is my experience of them with the UPA. If you select the 93S66 or any 93S option, you will see some check boxes for the procedure I have said. Read protect register will show you a byte of data, make a note. Clear the protect register will enable you to write to the eeprom. Write whatever you need to write. Write the protect register back (with the code it showed when you read it). If you don't write the protect register back to the eeprom you will have problems. If you have a equipment to do these eeproms it will do all of this procedure for you (in my experience). I don't think you can use 93c56 or cs or any othe 93 option to program these. I'm not 100% but this is my experience.
