ELM327 CAN pins selector for FIAT and FORD + k-line pin selector - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    62
    Downloads
    Uploads
    Might be worth introducing a another code to the system
    ( unplug a sensor of some sort ) just to see the results
    most codes will clear automatically after so many key-starts
    you will find a list of pids in attachment
  2. #32
    Jan 2016
    Downloads
    Uploads
    You mean sending a code like A2 or A3 ? Ax ? ... I guess to use those pids you attached the adapter must be modified right? Attaching another pin to pin 7.
  3. #33
    Jan 2016
    Downloads
    Uploads
    Quote Originally Posted by autotrans View Post
    I was able to clear the p0121 by doing this: ingition on/off -> ignition on for 30 seconds then engine start.
    I also found out that the program maxiecu (http://maxiecu.com.pl/download,6,en.html) works with elm327 and with the car, it's sending the same pids I found with vci. I tested the demo version.
  4. #34
    15
    Downloads
    20
    Uploads
    hi chriz are you sure maxiecu demo version works with elm327 ?
    because i tested it and dont work
  5. #35
    Jan 2016
    Downloads
    Uploads
    Quote Originally Posted by ammarben View Post
    Yes, I tried the demo, the program connects to the ECU through elm327 but the data it returns is "demo".. however monitoring the serial port I could see the PIDs it's sending for each data request.
  6. #36
    62
    Downloads
    Uploads
    there are a lot of free programs around, just bear in mind that most will
    only give you basic obd2 ( emission related data )
  7. #37
    Apr 2016
    17
    Downloads
    Uploads
    How to use ELM327 to communicate on K-Line (ex. ISO 14230-4)?
    Would it be possible to use an ELM327 instead of a VAG/KKL?
