Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    DK Veteran manocao's Avatar
    Default ELM327 CAN pins selector for FIAT and FORD programming + k-line pin selector
    adapter useful for:
    multiecuscan CAN programming (see ELM C19, adapter cable 3 Multiecuscan - Diagnostics software for Italian cars (Powered by FiatECUScan))
    ford CAN programming with elm-config + elm-ff2 + fds (Focus2, C-MAX, Kuga, Mondeo MK4, S-MAX, Galaxy)
    kkl interface k-line pin selection (iso 9141-2, kwp2000, kw1281, vag, opel, fiat...)
    components less than 10euro on ebay
    SAY THANKS!!
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  2. The Following User Says Thank You to manocao For This Useful Post:
    tango5 (5th February, 2019)
  3. #2
    mexanico1971's Avatar
    portugal
    always given easy and good solutions manocao !
    best regards
    My work is my life ART TECH GARAGE
    Default AT commands for FORD ELM327 CAN pin selection mod
    programmable parameter 2A only available from ELM327 1.3 or upper firmware version (edit: this is not true, also available for ELM327 v1.2a)
    edit: updated picture
    edit: AT command to show current programmable parameters: atpps
    example:
    >atpps
    atpps
    00:FF F 01:FF F 02:FF F 03:32 F means off (disabled), N means on (enabled)
    04:01 F 05:FF F 06:F1 F 07:09 F
    08:FF F 09:00 F 0A:0A F 0B:FF F
    0C:68 F 0D:0D F 0E:FF F 0F:FF F
    10:0D F 11:00 F 12:FF F 13:32 F
    14:FF F 15:FF F 16:FF F 17:92 F
    18:00 F 19:FF F 1A:FF F 1B:FF F
    1C:FF F 1D:FF F 1E:FF F 1F:FF F
    20:FF F 21:FF F 22:FF F 23:FF F
    24:00 F 25:00 F 26:00 F 27:FF F
    28:FF F 29:FF F 2A:38 F 2B:02 F
    2C:E0 F 2D:04 F 2E:80 F 2F:0A F
    to set all to defaults: atd
    to disable all parameters (set them off): atppffoff
    (note that these two commands don't revert programmable parameters to default values, even after reset or power off/on, you got to set them to default values by hand, see default values in the picture above)
    SAY THANKS!!
    __________________
    Might be worth adding pin 15 to the rotary switch K to L (with a make or break) it is used quite a lot on A CLASS mercs for example instruments ect.
    Quote Originally Posted by autotrans View Post
    it's ok, just use pin 15 instead of pin 11 or 13 in rotary swirch, i think pin 11 and 13 are never used in any ecu, i just added them in order to complete the rotary switch, but you can link the pins you need for your purposes
    __________________
  7. The Following User Says Thank You to manocao For This Useful Post:
    naser (24th March, 2013)
  8. #6
    Pin 11 is always transmission on mercs & pin 13 on EEC5 for reprogramming, they do a 12 to 1 rotary switch so it would be ideal to keep all options open
  9. The Following User Says Thank You to autotrans For This Useful Post:
  10. #7
    it's ok, so then use a 1P12T rotary switch instead, we can add 4 more posibilities for k line like this:
    1 -> fiat abs
    3 -> fiat airbag, opel eps + immo
    7 -> all engine, fiat automatic gearbox
    8 -> bmw ?, fiat immo
    9 -> fiat eps + climatonic
    11 -> mb transmission, fiat alarm + lock doors
    12 -> opel airbag + abs, fiat engine bay wiring
    13 -> EEC5 reprogramming, fiat rear wiring
    15 -> mb class A instruments
    empty
    empty
    empty
    please help complete pin features depending on car makes:
    2 -> any make not as sae j1850+ but as k line?
    6 -> any make not as can high but as k line?
    10 -> any make not as sae j1850- but as k line?
    14 -> any make not as can high but as k line?
    this is 1p12t rotary switch
    this is dpdt switch
    i forgot to include a knob
    __________________
  11. #8
    Default Scantool.net elm327 terminal
    use this to introduce AT commands for ford
    __________________
  12. #9
    Some early vauxhalls approx 1997 used pin 6 for engine ecu but not at 10400 baud , and early saab's used pin 14 without pin 6 but no idea what for
  13. #10
    i think you mean ALDL protocol working at 5v, elm327 or kkl no valid 'cos they work at 12v
    __________________
  14. The Following User Says Thank You to manocao For This Useful Post:
  15. #11
    Jan 2016
    Hello, I own a 1998 Mercedes A Class, it seems to me this thread is about switches for k-lines using elm327.
    The 1998 A Class w168 uses many pins for k-lines. Here's a scheme:
    Pins 1, 7, 8, 11, 12, 13 and 15 are all used for klines. The cheap elm327 bluetooth adapter from china only uses pin 7 and all obd software doesn't work.
    Can you suggest a solution? Switches for k-lines? I saw this post about a mod for Fiat that doesn't use switches but resistors: http://www.cardiagnostics.be/-now/Fi...ne_adapter.htm
    Do you think this solution could also work for thew A Class. What about the pin 3 TNA Gasoline ? Is that used to check ignition?
  16. #12
    don't know about mercedes pinout and protocols, i can't help, try and tell?
    __________________
  17. #13
    Jan 2016
    Hello, thanks for your reply. The protocol should be iso 9141-2, the pinouts is as in the scheme I posted.
    In your scheme you put also two switches for CAN, right? I don't think I need those for MB.
    I only need to access k-lines but maybe I am not getting the functionality of those switches.
    Could you advise?
  18. #14
    A class merc's use the kw2000 fast init protocol up to approx. 2004 bc ( before can )
    set elm ( SP5 )
  19. #15
    Jan 2016
    Hi, are you sure? What does 'set elm sp5' mean? Scan protocol number 5?
    Anyway I see obd iso 9141-2 and kwp2000 share the same pins. The point is multiplexed k-lines and switches between them.
