Results 1 to 7 of 7
    Hadron's Avatar
    Nov 2012
    E. London
    Default Skybox M3 "opening serial port is failed"
    Have an M3 here which just shows a red light when PSU plugged in. I have tried reflashing it, but get the message "COM test error!" "opening serial port is failed".
    I know that my null modem cable is OK, as I use it all the time to flash other boxes. I'm also using a pc with a proper RS232 port. I tried using another pc with the same result.
    I downloaded all the official abs files and tried them all, with the same results. I have tried waiting various times before plugging in the PSU.
    I'm running out of ideas. I think it maybe a hardware fault?
    DK Veteran nibblitz's Avatar
    Have you tried a different PSU?.. My original PSU went duff, I now use an old spare one I had from a netgear router?
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by nibblitz View Post
    Yep. I have just tried another 12v PSU rated at 2A. Same results.
    I sometimes get "set stb memory error" as well, but mainly it's the "opening serial port is failed" error.
    May 2012
    Probably not make a difference but try with power on hit start then power off and on. This used to work with dbox.
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by DW190 View Post
    Tried this quite a few times but still no good.
    Ahh...the old Dbox2. I never actually flashed one using serial only. I always flashed mine using the network method.
    if they are anything like openbox its all about timing? plus find unbricking works better with xp for some strange reason
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    the loaders were designed for older pc's that still have a serial port like from the xp days
