Results 1 to 11 of 11
    Sep 2011
    Midlands
    Default Blade Bm7000s channel list install help
    i have downloaded 2 channel lists from the download section but when i go into downloads on blade with usb plugged in its not showing anything. anyone know why? probably something silly (me being a dummy)
    digicon's Avatar
    You can use any of the Channel lists for the TM5402HD that are scattered around the forum.
    Sep 2011
    Midlands
    ive got the list downloaded onto my usb but when i go into utilities - download nothing shows up
    DK Veteran bj1's Avatar
    Sep 2010
    north wales
    Quote Originally Posted by Scottyboi View Post
    Have you format your usb stick if you have then try downloading another file,
    It will show up in utilities if the usb drive and file are valid,
    If you are just after 28.2 then you can always download from blade online on your menu
    Sep 2011
    Midlands
    formatted to fat32 then downloaded new list but still not showing up. regarding blade online list, i was after a sky channel list really
    Sep 2010
    north wales
    Yes m8 select uk astra 28.2e on blade online then select your region .....central. hey presto
    Nov 2008
    make sure your stick is fat32
    make sure you have unpacked any list if its packed in zip or rar
    the list should be ndf
    quite a few lists exist on here with an emphasis on 28.2e so do a search for one, like the happy highlander one
    Sep 2011
    Midlands
    Quote Originally Posted by ramjet View Post
    thats the one ive been trying to use (happy highlander). think ill retry tomorrow, had enough for one night. thanks for all the replies
    Nov 2008
    sounds like you did not unpack it first then as they unpack ok for me
    Sep 2011
    Midlands
    You must be correct because I have no idea what your talking about
    Nov 2008
    use 7zip and unpack the download and put the ndf file onto your stick
