Results 1 to 4 of 4
    leandroks's Avatar
    Brazil
    Default Kia Soul 2010 1.6 AT basic settings TPS
    Hi there a kia soul 2010 1.6 automatic has arrived on my garage today, i ve tried everything and i cant make the tps basic seetting, it runs smooth and ok, when i stop the car the idle is ok (750rpm), but once i take the foot off the brake pedal the engine goes to 1250rpm, sometime it does not happens. Does Any1 know if is there any procedure to adapt the tps or any other thing i can perform in order to get that fixed:::???
    Thanks a lot
    Dec 2011
    1.6 diesel or gasoline?
    leandroks's Avatar
    Brazil
    Gasoline, Thanks..
    Dec 2011
    I think you must have GDS.
    Do you clean Idle speed control actuator?Check ECU port for water.
