Hi m8,
Your file with EGR off by switch.
Pass in pm.
Hi m8,
Pass in pm.
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
luisitoeik (8th April, 2013)
hi m8,
thanks for the dump,
I have a question, there is a possibility, that the file does not activate the turbo???,
because that happens now,,,,and b4 its work ok,
b4 i have egr problem now that is ok,
b4 the cars turbo is work ok, now doesnt work, and now the car is in safe mode,,,
with u file, You could do something else?, or what u think?
thanks in advance,,,
L
the byte disable the turbo
boost controll OFF
For this ecu it is enough to raise EGR map to maximum value.
regards,
pawliukazz
hi pawliukazz, thanks for replying, can u help me?, thanks in advance Luis
Try to disconnect the EGR valve. In some cases when egr is off by switch, the ecu opens fully this valve.
Regaeds!
is it possible to have the pass please ?
