Page 1 of 6 123456 LastLast
Results 1 to 15 of 83
    jolidj's Avatar
    ITALY
    Default disable dtc error
    Hi friend . i have e big question for all dk forum.
    I have in my car with edc16 ecu P dtc error.
    i like to now the possiblity fo find this error in my flash ecu file.
    The P erorr is in exadecimale 16bit view .
    i serch this code , forixsample p01234 ,i dont find this number inside the file, i convert this in decimale value but same result.
    help me and dk peaple to resolv this problem. ore contact me in pm.
    thank all.
    mislav88's Avatar
    Mar 2011
    give more info about the car, and post dump here
    yas200's Avatar
    Jun 2012
    Estonia
    No problem all diesel CAR - all ECU
    need #dtc and flash
    all DTC inside in flash
    CHIPTUNING dpfoff EGROFF immooff edc17,med17 EEPDOM CRC EDC17, MED17,
  4. The Following User Says Thank You to yas200 For This Useful Post:
    kiwi1hu (9th April, 2013)
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by jolidj View Post
    thank all.
    Post you file, i can explain how find and remove dtc.
  6. The Following User Says Thank You to smayer For This Useful Post:
    pablo1971 (24th March, 2013)
    Mr Smayer, cold please share a general procedure for removing DTC from flash, and if possible how to find switches, turn off bytes for egr and dpf
  8. #6
    LaraVAG's Avatar
    Jun 2011
    its interesing post, coudl some one give procesure how to search code??
  9. #7
    jolidj's Avatar
    ITALY
    this is my file. is ford focus. i serch dtc error p 2585. this is exsmple to understand how to find dtc and delet this. help please . is interes for all.
  10. #8
    UK
    yes it would be nice to no how to remove dtc.
    MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
  11. The Following User Says Thank You to pablo1971 For This Useful Post:
    radb02 (11th April, 2013)
  12. #9
    P2585 DTC switch off.
    This is error registration and MIL light disable example ONLY!!!
    Limp mode (if it present by this error) will stay unaffected.
  13. #10
    jolidj's Avatar
    ITALY
    ok . if possible to expland how you find the error in my file?? thia is the question. help please.
  14. #11
    jolidj's Avatar
    ITALY
  15. #12
    i see 2 blocks of data modified, but makes no sense, tried 2d, hexadecimal, decimmal, numeric....what s the propper way to view dferences in order to make something ot of this
  16. #13
    Babos's Avatar
    Mar 2012
    I before pay 1000euro for explane
  17. #14
    Quote Originally Posted by ominimicu View Post
    There is only 1 byte significally difference at addr $1C6F0B.
    2 big block difference are new CSM - no need analyze it.
  18. #15
    darn ya got a lot of money mate
