Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 83
  1. #31
    jolidj's Avatar
    ITALY
    thanks for your contribure.... example. i have error p0757 with manufacture code 17141 . p0757 is 16bit exadecimal and 17141 is decimal. right??
    i serch in decimal 17141 ??? and ??? i put it 0 for delet the dtc???
  2. #32
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by jolidj View Post
    No!
    Do not change the fault code numbers. You must find the fault path and change that.
  3. #33
    jolidj's Avatar
    ITALY
    fault path??? i dont understant this. expland please ore give one example.
    thank you
  4. #34
    POLAND
  5. #35
    pawliukazz's Avatar
    Jupiter
    Quote Originally Posted by Diagnosticated View Post
    I assume you mean one or two fault tables for P-code and Manufacturer code. Yes these are sometimes in one or two blocks.
    By dtc-switch off tables I assume you mean fault class fault path table
    and behaviour table is presumably fault class table.
    It seems to me that fault class table never has value 000 so if you set fault class fault path for an error to 000 it can't look up the correct class (behaviour).
    Is that what you mean??? That method turns off up to 8 faults in one go, not one fault.
    I was talking more bout switching an individual error off by the detection and healing debounce. These are not so easy to find in EDC16 and when you change them, the ECU sometimes resorts to default values.
    From what i've experienced - all dtc codes and/or it's code blocks are in PXXXX codes. Only BMW has Manufacturer codes. Even Renault has manufaccturer codes in diagnostics, but PXXXX code in hexdump flash.
    I don't know what you mean by fault class and others. I don't know if my names are correct, but i learned it without damos and named them with my understanding about it. What i wanted to say, is if the dtc is not directly related to performance of the engine (egr, intake mpnifold flap, fuel cut relay and so on...) it can be turned of without any performance loss.
    I doubt that. if every dtc's behaviour table would turn off other 8 dtcs, it wouldnt make sense (to my mind)
    you dont even have to modify that table.
    All i'm saying - if you've done research, know how to disable it, and tested on many cars - you are good to go
    WBR,
    pawliukazz
  6. The Following User Says Thank You to pawliukazz For This Useful Post:
    Diagnosticated (30th March, 2013)
  7. #36
    pawliukazz's Avatar
    Jupiter
    This program cost 250 pounds. It has support only VAG EDC16. PPD and some bosch manual are good also. And other ecus you propably need to disable dtc once in a year... I dont think it's worth the money, when one dtc-off file cost 30 Euros.
    Only my opinion
    Best Regards,
    pawliukazz
  8. #37
    Mar 2011
    Quote Originally Posted by pawliukazz View Post
    WBR,
    pawliukazz
    Pawl....This is what I believe. I may be wrong.
    VW EDC16 use hundreds of VW specific codes some of them are also P-codes, some are not. These are arranged in blocks which Bosch call error class for error (DTC) Sometimes the VW codes are in one block and P-codes in another block. Sometimes the VW and P-codes are mixed in one block and sometimes the VW and P-codes are two different areas in one block.
    For Bosch EDC15, 8 error codes are connected to ONE error Path. (I assume it is same in EDC16). Each error path seems to have 20 or more settings to control MIL etc. There is not a 000 Error path as the block starts at 001. BUT Bosch do use 000 values in the error path so I assume 000 means NO ERROR path. With an Error path set to 000 the 8 errors (dtc) that connect to it will be disabled. This is 8 Potential error because not all 8 will be used. Sometimes only 1 or 2 are used.
  9. #38
    i agree with you all, nice software thanks, it will be my next cracking project
  10. The Following 3 Users Say Thank You to ominimicu For This Useful Post:
    dyc (31st March, 2013), pawliukazz (30th March, 2013), yas200 (1st April, 2013)
  11. #39
    pawliukazz's Avatar
    Jupiter
    I dont really follow... I'm not saying you're wrong, but edc15 and ec16 cannot be compared, they both have completely different dtc structure.
    But what i know for sure - every dtc or dtc block (depending on the manufacturer) has it's own switch, or as you call it "path"?
    as long as you disable correct bit, you are good to go, no other dtcs will be disabled. thats from my exprerience in edc16.
  12. #40
    Babos's Avatar
    Mar 2012
    I confirm edc15 and edc16 no same!!
  13. The Following User Says Thank You to Babos For This Useful Post:
  14. #41
    Mar 2011
    Here is what I mean.
    (16874)....P0490...EGR Control Circuit High.
    VW call this: CARB spezifischer Fehlercode fuer Fehlerpfad Dfp_EGRCD_Max
    Which I think means: CARB specific error code for Error Path Dfp_EGRCD_Max
    They also have this:
    17810...(P1402)...EGR Valve (N18), Circuit Short to B+
    This is called: Kundenspezifischer Fehlercode fuer Fehlerpfad Dfp_EGRCD_Max
    Which I think means: Customer specific error code for Error Path Dfp_EGRCD_Max
    So that is two P-codes (CARB) and 2 Customer (VW) codes all for Error Path Dfp_EGRCD_Max.
    So If I find Error Path Dfp_EGRCD_Max and set it to 000, it will be off but 2 CARB and 2 customer codes will be disabled.
    I have no idea if this is correct. All I know is that using this method has produced some strange results. That's why I wondered if you used the same method.
    The path (switch) always has a number like 001, 002 etc up to roughly 020. These are the bits I set to 000 to disable the path.
  15. The Following User Says Thank You to Diagnosticated For This Useful Post:
    mexanico1971 (23rd October, 2013)
  16. #42
    pawliukazz's Avatar
    Jupiter
    I think i understand what you wanted to say, however:
    if the ecu has 320 dtcs, then it will have 320 switches or paths as you say. Knowing that vag has bocks of 4x1 instead of one dtc it will mean that:
    (16874)....P0490...EGR Control Circuit High. - these two will probably be in one block (refers to the same dtc) it may have either two empty slots or simmilar dtcs like for example "EGR Control Circuit Low" And it does not mater if we disable both all of them because they all refer to the same dtc, but different status, meaning the same control circuit problem, however one is too high, other is too low. All of these dtcs "live in the same house" and are responsible for the same thing.
    These dtc may also be in different blocks, but other slots will probably be empty.
    Also i wouldnt trust damos naming for paths. Only the manufacturers can understand what they are naming...
    conclusion - (Only from my own experience) you must be doing something wrong if you are getting strange results, i don't know your solution to finding paths, but...
    Again i will repeat myself - i've never had problems with disabling dtcs whatsoever.
    Best regards,
    pawliukazz
  17. The Following 4 Users Say Thank You to pawliukazz For This Useful Post:
    Diagnosticated (31st March, 2013), Helos (4th October, 2016), Novik_UA (2nd April, 2013), WinWoj (1st August, 2017)
  18. #43
    Mar 2011
    Thanks for reply Pawl. That's what I mean. In my research each fault path (switch) is connected to a possible 4 P-codes and 4 VW codes (8 dtc's in total). It looks like we are talking about the same method. I find that I cannot always identify the exact start of the fault class block. I can find the first set of 4 codes but sometimes there are 8 x 4 rows of 0000 before this and sometimes 6 x 4 rows of 0000. I am not sure if the start of the block is always 6 rows infront or if it is sometimes 6 rows and sometimes 8 rows. Hopefully you know what I mean.
    My original research wasn't from DAMOS. I found the DAMOS names recently.
    I have only seen one VW DAMOS where the fault codes and fault paths are shown.
  19. #44
    spawns3's Avatar
    Portugal
    You don't even need a damos or few years for this, just some brains and basic logic. I learned mine in 1 week.
    BR,
    pawliukazz
    Maybe because u in that week search for a solution , but i have sure u don't find the solution alone , u search and figure out the strategy , in edc15 is very simple too , but u need damos to understand what to do . U have some edc15 with very similiar solution like edc16 , but is not only one switch.
  20. #45
    Mar 2011
    Quote Originally Posted by spawns3 View Post
    Yes the EDC15 solution seems to be to change the debounce values for Defect time and Healing time, so two switches. I believe you can do this for edc16 but the debounce defect and debounce heal addresses are hard to find.
