Page 6 of 6 FirstFirst 123456
Results 76 to 83 of 83
  1. #76
    Senior Member Diagnosticated's Avatar
    Mar 2011
    You just need to zero the fault paths table but if the file uses CAN you may still get errors flagged. You can't be sure until you try. It is different for different files.
  2. #77
    pepesound's Avatar
    Bulgaria-Radomir
    Hi need help clear dtc error P0401 -EGR.Fiat Croma EDC16C39 Bosch 0281012149.Thanks all in advance!
  3. #78
    Default hi
    i need remove dtc P2585 CMAX 1.6 tdci BOSCH 0281012489
    THANKS
  4. #79
    Jul 2012
    I followed the examples on the previous pages if you want to test this file and returns the result
  5. The Following User Says Thank You to mario38 For This Useful Post:
    gogoli (25th November, 2013)
  6. #80
    somewhere around here
    Hi guys, are any parts of the EDC16 dtc structure applicable to edc17's in any way shape or form?
  7. #81
    Sep 2013
    ES
    hi
    can you tell me where to buy this program?
    and if it works well?
  8. #82
    Sep 2013
    ES
  9. #83
    systemlinux's Avatar
    Oct 2018
    CDK
    interesting post only applies to EDC15P (web video) I do not want to infringe anything on the forum so I do not upload link
    in winols the tabs must be in:
    16 bit data - 255 hex - LO HI
    now in the decimal search byte P17554
    you place the DTC without letter (number only)
    found the cell, you must put these values as indicated in the image.
    I respect the masters in that area, it's a lot to learn.
