Results 1 to 9 of 9
    Mar 2013
    Default help required with openbox
    hi guys I have an s9 genuine box which I suffer with glitching from my line...I use an n line and its wired direct into a super hub..ive tried several firmwares and they all do it...ive spoken to other guys on the same server and they have no issues so im wondering if the skybox f3 will be a better box due to the processors or do you reckon im flogging a dead horse?
    DK Veteran nibblitz's Avatar
    I used to have an S9 myself, and I too have a superhub, the S9 worked fine all the time I owned it... I doubt you'll see any improvement changing your box, unless your S9 is a bit iffy...
    What one person might interpret as "no issues" might be "annoying as hell" to another..
    Mar 2013
    yes but I only use it for sports and its real annoying when it freezes I reckon my box is perhaps iffy im using an n line I may try to use the cline see if that helps
    digicon's Avatar
    Quote Originally Posted by sando1972 View Post
    You might like to take a look at the forum rules before you take this discussion on this subject any further: http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
    Thank you
    Top Poster Nutty34's Avatar
    Feb 2013
    Mate it will be an issue with Virmin, google Virmin lag. There are loads of people with issues. Obviously it could also be your CS server but if others are okay then Virmin it is.
    Posted using Tapatalk for IPad.
    DK Veteran sb18180's Avatar
    Sep 2012
    cheap boxes you cannot expect perfection for the price of them. same as anything in life the more you pay the better quality the item im most cases.
    Mar 2013
    sorry my bad
    99 times out of 100 its the server and not the box
    ive tried a few sealions with s9 and some are great some bad ,
    whats most annoying is that they can be fine for a while then go bad,
    just try another s9 works best with just 1 line at a time
    Sep 2012
    if it glitches on freesat channs say bbc1 then its your end!
