what tool do you have ??????
many tool
what do you mean...
This is a combine made the 1980's, correct? There should be a screw to adjust.
sorry mistake is 8220 model
2005
Do you have a tool to read and write this ecu?
dump in attachment
i dont think so beeprog+
also for me your read is not good
Ecu tuning, DPF, EGR and FLAP remove
What ecu is this? I can't really make sense of this file either. Can I have the ecu part number and possibly engine serial number? Is this a common rail fuel system or a electronically controlled mechanical style pump?
This should be a level 9 ecu. If you can read via can line, then maybe I can help you. File size should be 32kb. Attached is a picture of the possible location.
milkatrek (30th March, 2013)
Here is the pin-outs to read via CAN. L11 & L9 ecu is the same pin-out.
compere whit ori file her
I use galletto3. Where is problem ?
