Remove FAP ford bosch 0281015242
Results 1 to 10 of 10
    Member ingeniero222222's Avatar
    152
    Downloads
    354
    Uploads
    Default Remove FAP ford bosch 0281015242
    Hello.
    A partner who can remove the FAP to this ECU? Ford Focus.
    Thank you all for your interest.: Hmmmm2:: Hmmmm2:
    kevfield's Avatar
    uk
    373
    Downloads
    75
    Uploads
    4
    Hi try read ecu again your file does not look good to me .....
    Thanks kev
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    104
    Downloads
    47
    Uploads
    I will try to help you byt you'r file is incomplete around 400kb it should be 2 mb
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
    152
    Downloads
    354
    Uploads
    Quote Originally Posted by kire106ka View Post
    Sorry mates.
    This file is read again.
    Thanks for everything.
    Nov 2012
    smartville in front of a OBDplug
    36
    Downloads
    10
    Uploads
    i can do it but need the checksum my tool make checksum automatically
    kevfield's Avatar
    uk
    373
    Downloads
    75
    Uploads
    4
    Dpf off
    Make sure your tool correct checksum
    Thanks kev
  7. The Following User Says Thank You to kevfield For This Useful Post:
    ingeniero222222 (27th March, 2013)
    152
    Downloads
    354
    Uploads
    Thanks Kev, I need the pass please.
    Greetings.
    kevfield's Avatar
    uk
    373
    Downloads
    75
    Uploads
    4
    Check your pm
    Thanks kev
  10. #9
    Aug 2012
    LATVIA
    12
    Downloads
    12
    Uploads
    28
    Downloads
    6
    Uploads
    Please make dpf off in my Bosch 0281015242 ECU file.
    BDM 1255 will make correct checksum?
    Thank you
