Results 1 to 7 of 7
    Top Poster crashcar's Avatar
    Jul 2009
    USA
    Default 2011 Jaguar XF Smart key programing-ALL keys Lost
    Hello.Please ,can anybody guide me thru programming smart keys for 2011 Jaguar XF.Using JLR.Can't figure out.Any inputs highly appreciated.
    kevfield's Avatar
    Aug 2009
    uk
    Open SDD JLR connect to car select Diagnostic , then Selected Symptoms select on tree select Body + Security and locking + Anti-theft immobilization system + Passive anti-theft system lamp then high light inopertive , flashers , flashers with ignition on and constantly then hit continue it will then load up recommended canididates! Then the top tabs select Service Functions in that tab you will find Security-Key programming hit run and your off to programming new key.......
    Hope this helped
    Thanks kev
  3. The Following 6 Users Say Thank You to kevfield For This Useful Post:
    Adamon777 (2nd October, 2018), clauberty (17th April, 2018), crashcar (27th March, 2013), dekimin (4th October, 2018), flyins (27th March, 2013), kronk92 (4th October, 2016)
    Nov 2009
    worldwide
    this tool can program your key even if all keys are lost .
    Best Regards
    Quote Originally Posted by kevfield View Post
    Hope this helped
    Thanks kev
    JLR_v10.pdf
  5. The Following 2 Users Say Thank You to Dashcoder For This Useful Post:
    crashcar (27th March, 2013), kevfield (27th March, 2013)
  6. #4
    gwee's Avatar
    Dec 2012
    unknown
    Hope this helped
    Thanks kev
    Hi Kev,
    Thanks for the good info.
  7. The Following User Says Thank You to gwee For This Useful Post:
  8. #5
    May 2012
    HI!
    I have official SDD and try to programming (all key lost) new key like your instruction, but car request ignition ON, how use SDD when all key lost?
  9. #6
    Jan 2018
    The same.
    Im use option add key in SDD v 158
    And as a result, I now have a problem with IMMO.
    Shows me
    PID C124: bytes 1-4; bit 3=0
    Run "Immobilisation fron security menu etc....
    after executing the command:
    I can lock and unlock car Thats all.......
    Information on dash "Sterring Column Lock " (Column is not locked)
    No chance to start ignition ??
    Any tip how to fix this
  10. #7
    Jan 2017
    USA ����
    Pay to play
    The thanks button is HERE looks like this --->>> THANKS
