Results 1 to 3 of 3
    borysgo2's Avatar
    Default Micra K12 timing chain - check
    Hello
    Micra K12 timing chain problem and fault p0340 - quick solution to check it (duration 4 min).
    You need oscilloscop with 2 channels.
    BTW almera 1.5 is the same procedure.
  2. The Following 6 Users Say Thank You to borysgo2 For This Useful Post:
    a1decode (2nd April, 2013), br.balazs (8th November, 2018), brumaovidiu (13th April, 2013), Dunker (30th March, 2013), lmsvvavr (10th May, 2016)
  3. #2
    quinnd's Avatar
    Jul 2012
    NZ
    We do this all the time in our workshop. What we want to know is at what point does the ecu log a code for cmp/ckp sync? The cpu must be looking for the switch low of cmp within a certain time period or something. Who has brains?
    Xprog-m, CarProg, MPPS,
    AK90
    SBB
    VAS5054a
    SuperVag K+CAN plus
    AD900
    CN900+4D decoder box
    4D Cloner
    Toyota smartkey maker
    Volvo Vida DiCE
    BMW GT1 DIS SSS Progman
    +loads more chinese stuff
    + the excellent help of DK forum!
    Dec 2012
    uk
    you must to change timing chain with sprocket and tensioner
