asiprens64 (29th March, 2013)
I have hyundai ix35 2011 ,I decided to adjust its odometer from 11200 to 4000 KM,I find inside Eeprom s93c66 ,I adjust it manual by Tacho soft 2.1
,,the problem is many times adjust it but no good result every time I adjust it the temprature and the fuel gages are changed , the temprature is full and the fuel gage is empty but the KM is 4000 ok,,
But the problem now is the gages ,,,
any Idea ,,,
send original reading ... and ori Value..
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
asiprens64 (29th March, 2013), cardiagprofi (14th November, 2019)
i use tachosoft 23.1today and works perfect
if need help send dump i corect, maybe bad reading or bad soldering, you read in ic or desoldered?
puts this file and see if everything works ok
This is from a dash recalibrated to 50000km, if works then edit with tachosoft 23.1, if need help reply...
can you send this file to my email thank you
Hello Friends,
I have a hyundai ix35 2018, i decided to set the mileage, can someone help me as i can do it the easiest? Digiprog reads, eeprom modifies and rewrites? Something I can ruin?
