Results 1 to 4 of 4
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default Op-Com Astra H DIS Coding
    does anyone know how to code/change index code to allow BC in display
    13253694,13238548
    Without BC
    Linear Voltage, Type B
    009
    to
    13253694,13238548
    With BC
    010
    Many thanks
    Aug 2011
    Spalding
    Yes but remember its has to be a BID GID or CID
    You cant activate BC on a TID.
    Vauxcom or Tech 2 will do it. Some opcom clones may.
    From memory its Infotainment/Display/Programming/Code index or words to that effect.
    Martin
  3. The Following User Says Thank You to MJRVR For This Useful Post:
    teerak2uk (30th March, 2013)
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    So tid is located on dis or h/unit?
    Aug 2011
    Spalding
    Tid stands for triple info display, its the one with two buttons at the bottom, this one cannot have the computer switched on.
    The ones without buttons can be activated.
    All programming is done on the display, not the head unit.
    Martin
  6. The Following User Says Thank You to MJRVR For This Useful Post:
