Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    DK Veteran sb18180's Avatar
    Sep 2012
    Quote Originally Posted by LeonRead View Post
    Any CLONE SKYBOX (F3 ,F5) CAN NOT run the firmware , EVEN upgrade the firmware with a RS232 cable.
    if you get file mismatch then send it back there is some bad/clones? going around
  2. #32
    Quote Originally Posted by bptuc View Post
    @bbb_uk
    I also have restarts after updating to this FW. I noticed that these happen when my resolution is above 720p. Can you confirm it? Should we downgrade to 13-01-2013 FW?
    I today have just restored defaults, removed channels and re-flashed with March firmware but without keeping dbs and settings in hope that this will solve it. I will post back later today or 2mo on whether it makes a difference.
  3. #33
    Apr 2013
    Anyone know how to change pin menu ccam (6666) in the skybox f3? thank you
  4. #34
    @bptuc
    It's been 6 hours and solid, no reboots. Beforehand, it would have rebooted several times by now.
    So assuming all stays well, it's worked.
    All I did was:-
    1. backup everything(!!!)
    2. restored defaults and when prompted what else to erase I selected everything.
    3. Deleted all channels.
    4. Rebooted by pulling out DC jack for few seconds.
    5. Reflashed with March firmware from skybox.cc but selected NO, not to keep DBS and settings.
    6. Rebooted by pulling out DC jack for few seconds.
    7. Ensured my ethernet was still active (it was) and changed other settings to do with area/time, etc and added a few other things!!!
    8. Rebooted.
    9. Added my channel list (which I slightly amended AJs end of March channel list - thanks again to AJ)
    10. Rebooted by pulling out DC jack for few seconds.
    That's it. I realise that I probably went overboard on what I did but as I wasn't sure why I had reboots when obviously most others haven't I thought I'd best be cautious and overboard it was
    Unfortunately, you will have to rename your Favourites.
  5. The Following 2 Users Say Thank You to bbb_uk For This Useful Post:
    boylan (12th April, 2013), bptuc (12th April, 2013)
  6. #35
    Apr 2013
    Default youtube only works with files under a minuite long
    Quote Originally Posted by badboy1965 View Post
    still my youtube does,nt work ,youp##n does but stutters, and still carnt get all the sats in the list to show (only 4 showing same as before)
    I am running a f5 and youtube went from not working to working ok on small files.
    files of 1min and over stutter also channel change has gone from being unpredictable to ok.
  7. #36
    Quote Originally Posted by bbb_uk View Post
    @bptuc
    All I did was:-
    8. Rebooted.
    I hope now it's stable. When I updated the FW I did not factory reset. I will follow your steps, do a factory reset also AFTER reflashing.
    Thank you bbb_uk
  8. #37
    Oct 2011
    bbb_uk i cant thank you enough after i have done this everything is working correct!
  9. The Following User Says Thank You to boylan For This Useful Post:
    bbb_uk (12th April, 2013)
  10. #38
    Thank you bbb_uk
    Have you tried it yet?
    The factory reset is BEFORE reflashing in what I did. It's still working fine for me now.
  11. #39
    Apr 2013
    after update anyone facing scramble problem??? but I use back old firmware can watch...
  12. #40
    Quote Originally Posted by omega17 View Post
    Nope not me.
  13. #41
    Apr 2013
    Hi, i have found my box has restarted by itself since the update was installed also
  14. #42
    Quote Originally Posted by mc86 View Post
    I had that. See my previous post #34. Mine has been ok since.
  15. #43
    Member deano16's Avatar
    Jan 2013
    sheffield
    Used this update this morning!! As my youtube wouldn't play!! All working fine now since update, no issues what so ever thanks
  16. #44
    Mar 2012
    When whatwearenotaloudtotalk about disconnects the channels says scrambled I thought it was meant to say invalid program?
  17. #45
    Jan 2013
    Hi all
    I have a skybox f3 could sombody tell how to put latest firmware onto the box, do i need to delete the firmware(3601HD_10_05_2012_073A) i have on it, before i put the latest one on, any help please
