Results 1 to 10 of 10
    May 2012
    Default EPG not auto updating
    Im running blackhole 1.7.4 and my cross epg doent auto update , if i reboo the box the new tv guide will then show up.
    can anyone help???
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    It sounds like you have crossepg settings on flash memory rather than hdd or usb. In configure it should be on media/hdd or media/usb depending on what you have attached. Do you have it set for scheduled download? Go and check your crossepg settings.
  3. The Following User Says Thank You to DOUGALMCD For This Useful Post:
    wastedspark1982 (3rd April, 2013)
    DK Veteran lincsat's Avatar
    Jun 2008
    If you are saving to USB or HDD and it's configured properly, then delete the contents of the /media/usb/crossepg or /media/hdd/crossepg/ folder, reboot the box and run the downloader again.
  5. The Following User Says Thank You to lincsat For This Useful Post:
  6. #4
    May 2012
    I altered where it was saving last night to media/hdd last night and all worked fine this morning
  7. The Following User Says Thank You to wastedspark1982 For This Useful Post:
    DOUGALMCD (3rd April, 2013)
  8. #5
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Glad to hear your sorted.
  9. #6
    Sep 2010
    Quote Originally Posted by lincsat View Post
    you would first need to place enigma into sleep mode with a telnet session as EPG data is held in live memory., so when you reboot the box it will just rewrite the corrupted data back to the storage media.
  10. #7
    May 2012
    Well i thought it was . I looked this morning and it didnt update its self i had to manual update it.
    checked where it is saved to hdd/media/dat.
    Im stumped
  11. #8
    Jun 2008
    Quote Originally Posted by RuberDuck View Post
    Not using CrossEPG in Blackhole it doesn't, done it 3 or 4 times over the last couple of Years. Try it and see, the Crossepg folder is still empty after the reboot.
  12. #9
    May 2012
    Sorry i dont know how to do what your asking, can you guide me through?
  13. #10
    Sep 2010
    image makes no difference what so ever here, EPG data is held in live memory same as bouquets data on ALL images.
