Results 1 to 15 of 15
    mitext's Avatar
    Feb 2011
    Default GOLF 3 NEED ORI DAMP DASH
    hI! NEED good damp dash golf 3 MOTOMETER 1H6.919.033-N, SW5.8, HW6.0 ... THANKS
    bmwparts's Avatar
    Apr 2010
    RSA (where men are men and sheep are nervous)
    Try this file. Not sure what hw or sw version. All I know it was from a Golf3 MM cluster.
    golf3_mm_cs56_150kkm.rar
    If things seem under control, you are simply just not going fast enough!!
    mitext's Avatar
    Feb 2011
    the oil light flashing and water
    bmwparts's Avatar
    Apr 2010
    This is only other MM file version 5.1
    golf3mmsw51.rar
    mitext's Avatar
    Feb 2011
    dont working
    Nov 2011
    Has it the 8 PINS or 14 PINS 93C56 ?
    mitext's Avatar
    Feb 2011
    eeprom 14 pins
    mitext's Avatar
    Feb 2011
    Does not anyone help?
    Nov 2011
    forget : does it have a rpm or an analogue clock instead ? otherwise make a pic from it
    mitext's Avatar
    Feb 2011
    tomorrow will attach photos
  11. #11
    mitext's Avatar
    Feb 2011
    post picture dash
  12. #12
    rubin_miki's Avatar
    Nov 2008
    MAKEDONIJA PRILEP
    Try this dump
  13. #13
    mitext's Avatar
    Feb 2011
    there is no difference ...: (
  14. #14
    rubin_miki's Avatar
    Nov 2008
    MAKEDONIJA PRILEP
    Did you test in the car or out of the car?
  15. #15
    mitext's Avatar
    Feb 2011
    test it in the car, once the tachometer does not work, sometimes the trip computer does not work ,with different files
