Results 1 to 15 of 17
    Default skybox f3 scrambled after update channel list ????
    hi all , i recently updated my skybox f3 to the latest channel list using usb stick and guide on AJs site .
    the new channels now appear on the channel listing but unless the channel is free to air they are all coming up as scrambled . i have tried to update the list a few times but same result
    does anybody know of a fix to this problem please ???? i feel like tearing my hair out off work for a week with no sports channels
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    check in network settings and make sure dhcp is on.
    If it isn't broke, don't try fixin it..!!!
    hey thanks for reply ive checked network setting but dont see anything about dhcp . i just have 2 boxes , one for ethernet and one for wifi .i am using ethernet cable and that box is checked green
    Jun 2011
    Bolton, Lancs.
    If you click on the ethernet settings it should be in there.
    P&D's Avatar
    Hi Silly question but someone has to ask it....
    Have you checked thepartwecannottlakabout is online/login/offline ?????
    Oct 2011
    Contact who you subscribe to...... i had this problem its usually who you subscribe to not broadcasting the correct stufff...... most will tell you the correct channel list to use
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Are you certain you only updated the channel list and not everything else?
    Andy
    P&d how do you check if its online offline or not
    DK Veteran mahrkpat's Avatar
    Jun 2012
    To check if your dchp is set to on or whether secret ingredient is on you need to get into the network settings, to get into the network setting you have to press menu on the remote then press 6666 to access secret menu.
    Apr 2013
    Hi all, this is my 1st post.
    I have the same problem, I have just had my F5 installed, wanted a channel list and downloaded AJ's, and followed the backup instructions. I had problems getting the channels working, etc, but once completed I cant access any of the channels with a $, and some others, only a few working. I have DCHP on, and pretty sure other is too, I can see it in hidden menu. Before i attempted to update channel list I had sports, etc, so pretty sure its something I've done, any advice would be great.
    DK Veteran sb18180's Avatar
    Sep 2012
    the satbox and channel list alone only gives you free to air channels. hidden menu can be found highlight the globe network local settings and press 6666
    Apr 2013
    Hi, thank you for quick reply, I am coming up as online on 6666 menu, yet most of channels are not working, even free to air ones aren't showing for me
  13. #13
    Sep 2012
    fta not working are they saying no signal
  14. #14
    Apr 2013
    Yes there not working either, some are and some arent, e.g. bbc 1, 2 and channel 4 ok, ITV and 5 no signal. They were all working before I tried adding channel list but now they've gone too, which is why I believe it must be something I've done, but cant think what
  15. #15
    Sep 2012
    you using more than 1 satbox?
  16. The Following User Says Thank You to sb18180 For This Useful Post:
    JayA1985 (12th April, 2013)
