    Mar 2011
    Default Anything bigger than a Octo LNB solution?
    Currently running an octo LNB with all feeds in use but I now need another feed bringing my total to 9, is there anything available or is it simply a case of another dish and lnb?
    Living In Ireland and the dish is fixed to Sky, all the feeds are for Sky.
    Many Thanks.
    Dec 2011
    As far as I know 8 is max... Another dish would be my answer.
    Sent using Tapatalk
  3. The Following 2 Users Say Thank You to BigfatPaulie For This Useful Post:
    neolxs (3rd April, 2013), ramjet (3rd April, 2013)
    DK Veteran bj1's Avatar
    Sep 2010
    north wales
    If you want more than 8 feeds then you can replace your octo for a quatro then run in to a multi-switch this would cost you a over ?130 so maybe another dish if this is to expensive for you
  5. The Following User Says Thank You to bj1 For This Useful Post:
  6. #4
    digicon's Avatar
    EMP Centauri switches can run on standard Quads or Quatro LNBs prices start from around ?80 for a 12 out from a quad including terrestrial feed as well, Dont forget once you start using switches if you only have one cable in some rooms then you will need diplex plates for the Aerial feed as well
    Apr 2012
    I had the same issue and the cheapest easiest in my opinion was another dish with a quad ?25, fitted myself.
  8. #6
    Feb 2013
    Near Southampton
    Default Extra feed number nine.
    Do any of your recievers have an lnb outlet ? You could use this to feed another reciever but with the polarity restricts of course.
