Page 33 of 56 FirstFirst ... 23282930313233343536373843 ... LastLast
Results 481 to 495 of 836
  1. #481
    Sep 2010
    Great tut thanks!
  2. #482
    Oct 2010
    Great guide, but i'm facing some problems..
    do i have to perform flash erase first?
    if i do the flash and pick the image the upload fails and i get the message "user aborted" or something similar..
    the backup also failed..
    any ideas?
  3. #483
    DK Veteran piopat's Avatar
    May 2008
    you dont have to do a flash erase on a dm500s but i recommend it , if dream up is saying aborted by user etc you need an older version . try the links in my signature area.
    i love it when a dreambox comes together.
  4. #484
    Default Flashing DBOXS with DBOX cabel image
    Is it possible to flash DBOXS with DBOX cabel image.
    Regards,
    Arben
  5. #485
    Oct 2010
    Quote Originally Posted by piopat View Post
    i downloaded dreamup 1.2.2 and tried to do a flash multiple times but i get the message
    12:16:42 pm ERROR, flash-erase failed, box will be unusable now!!
    the same happens with dreamup 1.3.3.6
    then i tried to flash with dreamup 1.2.2 but it starts to upload the image, then the speed descreases slowly from 11kb/s at the beggining to 7,6,4 Kb/s and finally i get the message ERROR, upload aborted!
    is the box destroed? :/
  6. #486
    May 2008
    it sounds like you flashed the wrong image or you never unzipped or unrared the image .i had that message before on a dm7020 and i sorted it by using the correct dreamup for the box and by flashing on a desktop computer using just a null modem cable.you say you flashed multiple times (i assume without erasing the previous flash) im attaching an older version of dreamup for you to use which worked fine for me on a few dm500s.i uploaded to the download section also for anyone else that needs it in the future.
  7. #487
    Oct 2010
    i tried dreamup versions:
    1.3.3.6
    1.3.2.1
    1.3.3.4
    1.2.2.0
    the version 1.3.2.1 (is the one you attach) worked smoothly without any problems, so is a matter of correct version of dreamup (it's a little bit strange but this is the fact)
    Thanks once again for your valuable help!
  8. #488
    May 2008
    your wellcome mate ,i know they say that newer versions of dreamup such as 1.3.3.6 and 1.3.3.5 are universal and so should work on all dreamboxes but in my experience its not the case . if your box is a dm500s use the version i attached above if your box is newer such as the dm500hd or the dm800 (if your going to flash via a null modem cable)use the newer versions or flash via web browser.
  9. #489
    Oct 2010
    HI Guys,
    New here. I have the same problem on the User Aborted with DreamUp 1.3.3.6.
    Will download the version posted here and try again.
    Thanks everyone
  10. #490
    Oct 2010
    i 'm pretty sure that the version 1.3.2.1 will work for you...
  11. #491
    Oct 2010
    Excellent instructions. Thank u...
  12. #492
    Oct 2010
    Quote Originally Posted by leexgx View Post
    the zip file on here has no exe in it what ever i download it as the same name shows up inside the zipfile if
    used the below link now its working the link on this topic needs updateing
    Digital Kaos - Downloads - dream up v1.3.3.2
    ---- old
    been haveing the same issue on 2 systems that keep saying aborted by user
    need to wait 20 mins if it is corect that i have to post in the welcome thread
    hope the older version works on here, been driveing me mad this dreambox as its bricked at the moment as the update via FTP is now makeing it reboot all the time (just get the DK logo then it reboots)
    yoink!...............
  13. #493
    Nov 2010
    I wanted to flash too, but what image should i install?
  14. #494
    May 2008
    what box do you have mate?.
  15. #495
    Oct 2010
    as newbie, have been reading piopat,s tutorial . be grateful if anyone can tell me can i use a mac (computer) to use with dreambox 500,(flash box etc) thanks
