Page 47 of 56 FirstFirst ... 374243444546474849505152 ... LastLast
Results 691 to 705 of 836
  1. #691
    Nov 2008
    N*L EIRE
    Quote Originally Posted by clifet View Post
    been having problems with this dreamup
    If you want help you will need to give more detail
    Best to use null-modem from rs232 serial port on computer.
    Make sure com-port settings are correct
    If using USB-rs232 cable you may need to download correct drivers Accompanying disc don't always carry drivers to enable cable use Dream-Up.Found these worked with cheap cable
    Digital Kaos - Downloads - R232 USB TO SERIAL CABLE DRIVER
    If box is DM800 take a look here
    Digital Kaos - Downloads - DreamUP Patched dm800 clone
  2. #692
    Feb 2012
    Default help
    hi everyone,my dreambox 800hd just got error message when i downloaded some new add ons ,i think it has the new enigma 2 image , bought it off a trader with the cs now i have read that it will have to be reflashed with dreamup will this lose my cs info as i dont know that much about these done cable things in past flashing etc so not a complete newbe but all the help possible will be gratefull thanks everyone
  3. #693
    DK Veteran piopat's Avatar
    May 2008
    if you installed addons and your getting error messages go back to the addons menu and uninstall them ,and see if the error message disappears .
    i love it when a dreambox comes together.
  4. #694
    Feb 2012
    wow sounds so easy..hope it is
  5. #695
    Feb 2012
    Post
    I have clone and this same message lcd on the dreambox still says "error! look at _www_dm7020_com *ERR01: NO CA FOUND"
    I try diffrent dreamup and pc no connect to box i check hyperterminal no connect.
    What can I do?
  6. #696
    Nov 2008
    N*L EIRE
    Quote Originally Posted by local View Post
    What can I do?
    Try this version, recommended for DM800, but should work on 720
    If not try Digital Kaos - Downloads - dreambox enforcer
    Or try 1.3.3.4 works on DM800 no CA found
    Digital Kaos - Downloads - DreamUP 1.3.3.4
    Following version(5) is rated most universal
    Digital Kaos - Downloads - DreamUP V1.3.3.5
    If all above fail try this
    Digital Kaos - Downloads - Patched Dreamup
    OR
    Digital Kaos - Downloads - dreamup 1.3.2.1
    Sorry about all the versions but some suit one box & not another. DM500 & DM800 are most popular boxes & most
    software etc. is designed for popular Dreamboxes.
    Most important when using Dream-Up to ensure correct com/port is selected & Image chosen is compatible with your Dreambox i.e. bootloader etc on image matches box types
    When you find correct version of Dream-Up for your box you could try "select network" method when flashing box. It takes less than 3 mins. You need both LAN & null-modem cables
  7. #697
    Feb 2012
    Post
    This problem is solved with DreamUp V2.14b.
  8. #698
    Feb 2012
    i have successfully flashed 2 500c but only have FTA channels, black screen on all others..any help on keys etc to resolve this?
  9. #699
    Feb 2012
    \im trying to flash but when I connect the db everything just stops, what am I doing rong ????
  10. #700
    May 2008
    jedimaster i just replied to your pm mate .
    djax666 you will have to be more specific mate ,what dreambox do you have ? what version of dreamup do you have ? or you using a usb to serial adaptor with a null modem cable ? give as much info as you can and maybe we xan help you .
  11. #701
    Nov 2008
    N*L EIRE
    Quote Originally Posted by jedimaster1878 View Post
    Jedi, think you are UK based. If you had DM500s boxes with Sat-dish there are many ser*ers for C/S at around 100-150 per year. Your boxes are DM500c, so you need a cable server for UK.
    Am sure they will contact you by PM, as they scroll thru DK &
    similiar sites looking for business. If they don't contact you PM your e-mail to me & I will look 'round for you
  12. #702
    May 2011
    where on my pc do i connect the null cable? and how many pins on a null cable? i have a new pc this week if that helps
  13. #703
    Mar 2012
    Default I'm new...
    Hi nice manual, will try this to get my bootloader working.
    My DM800HD will not boot anymore....
    Regards, Ed
  14. #704
    alotmentman
    Guest
    9 pins mate u might need usb to r332 adapter
  15. #705
    Nov 2010
    Can i do a re-flash using this method for DM 500c?
    recently my DM500-c died suddenly but LED is on?
    i cant download the dreamup cause not enough post count i think?.
    help please.
