Page 5 of 54 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 836
Hybrid View
    Scotland
    great mate thanks for the tips.
    Dreambox on it's way! can't wait.
    Jun 2009
    Change the port!
    Dec 2010
    Quote Originally Posted by glasgowkiss View Post
    When I connect power nothing happens?
    Any idea...?
    I have the same problem but no idea how to get it working
    Apr 2008
    initally when you load dream up, do you choose com1 or two from the drop down or do you leave them do you tick the box marked " used network"?
    Apr 2008
    Quote Originally Posted by bash View Post
    i load com1 m8 i just need help
    Administrator
    Devilfish's Avatar
    Feb 2008
    You use which ever suits your needs. Most PCs only have one com port so select com1.
    If you are only using a null modem cable then don't check the 'use network' box.
    Jul 2008
    Hi when using dreamup there acouple of things you need to follow i have read through the guid on how to flash the box which is detailed with very good instructions.
    the answer to the question is when using dreamup u can start by using com1 and untick use network.
    <--jkateete added 31 Minutes and 55 Seconds later...-->
    The problem is not dreamup not working i'd the same problem before and it took me some time to flash my box. the problem is the type of computer your using the com ports are disabled which was the case with my pc and i didnt have enough knowledge on how to enable them, i tried several pcs but they all didnt help me as the com ports were all disabled untill when i used my old pc with com ports not disabled. Most the of the pcs these days come disabled you need to find some one with good pc skill to enable your com ports and use a latest version of dreamup.
    Every thing should work out properly once you follow the instructions thanks.
    Last edited by jkateete; 11th July, 2008 at 10:05 PM. Reason: Automerged Doublepost
    DK Veteran alliv's Avatar
    Jun 2008
    Quote Originally Posted by jkateete View Post
    hi , do you have the info to enable the ports ? or where can i get it? got the same problem at the mo. thanks.
    is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
    Top Poster Sig-gotyouth's Avatar
    Jul 2008
    If someone could please help me it would be appreciated. Just got a 500c from dvbseller... stright out of the box trying to follow these instructions but when I turn on the box nothing happens in DreamUP.
    sig-gotyouth@hotmail.co.uk is my msn for any kind soul that wants to help me out...
    Administrator
    Devilfish's Avatar
    Feb 2008
    There's not much else to say other than what's in the guide.
    Turn the box off
    Connect the null modem cable to the dreambox and com1 on your PC
    Run Dreamup
    Click connect
    Turn on Dreambox
    The progress bar will start to move on dreamup and it will upload the bootloader to the dreambox.
    If nothing happens when you power on the box, you've either got a problem with the box or you are not using a null modem cable. A serial cable and an rs232 cable look the same but they are not a null modem cable.
    Mar 2011
    Default flash 7020
    looking new version of enigma for dm 7020
    Apr 2008
    do you have to put the ip addresses in?
  13. #13
    Apr 2008
    Default dreambox
    hi ive got a dreambox but i do not know how to fix it as it has gone it keeps on saying service could not be found this hppend after the keys rolled can u show me how to fix it or is there an easy way of doing it . also do u have to connect the dreambox to ur computer and ur TV simultaneously to flash it. and can u use a trial version of smartFTP of do u have to get a full license for it to work.THNX
  14. #14
    Apr 2008
    Default Dreambox
    Sorry. but i also heard about autoupdating keys and stuff like tat does tat mean tat the box will not go out ever again.
  15. #15
    Member lorrebreaker's Avatar
    Apr 2008
    North West, UK
    Follow the instructions in this thread and you should be fine
    http://www.digital-kaos.co.uk/forums...ead.php?t=1273
    Trial version of smartftp will still work for a limited period, or you could use a free client like filezilla.
